New to me Softail with error code "d01clr"
Old Aug 20, 2011 | 02:58 PM
grizzwold's Avatar
grizzwold
Default New to me Softail with error code "d01clr"
Hey guys! I just picked up a new to me '97 Softail and after coming back from a short 20 mile ride I noticed an error code. It is d01clr. It seems to go away after I get rolling but comes back after I turn the bike off/on. Anyone ever hear of this? I plan on picking up the service manual this week but I was hoping to try and diagnose it sooner. Thanks!
Old Aug 20, 2011 | 03:26 PM
Spanners39's Avatar
Spanners39
Last time I saw this code it was the wires to the black **** that toggles between Odo, and trip mileages had got trapped between the tank and the console and were shorting out.....worth a look mate as it only cost an inch of insulating tape to fix :-)
Old Aug 20, 2011 | 04:07 PM
95yj's Avatar
95yj
Actually, I believe the D01clr means you are at position D01 and there are no trouble codes (clear) for this position. If this is showing all by itself when you turn the bike on, then the reset button or wire is shorted out as Spanners stated. It's acting as if the button is pressed while you are turning the ignition on.
Old Aug 20, 2011 | 04:28 PM
grizzwold's Avatar
grizzwold
makes perfect sense. the PO replaced the stock tins with Fat Boy tins. so far I've had to re-wire the brake/tail light and the rear turn signals, may as well see whats waiting for me under the console!
Thanks for the replies. I'm sure I'll be spending a lot of time around here
Old Aug 21, 2011 | 04:22 AM
Spanners39's Avatar
Spanners39
Be sure to keep us posted on the outcome....
Old Aug 22, 2011 | 08:10 AM
grizzwold's Avatar
grizzwold
WOW...you guys are pretty good! As soon as I loosened the console and turned on the ignition the error code was gone. I saw the wires that were pinched and re-routed them. Problem solved. Thanks for all the replies!
Old Jun 18, 2024 | 01:20 PM
HeritageJohn's Avatar
HeritageJohn
Stage I
Just want to say thanks. Had this issue for a while but couldn´t find a clear solution online until I saw your post.
Jared0869
Electrical/Lighting/Alarm
Jul 28, 2017 11:51 AM
phknsic
Jan 29, 2011 11:54 AM
captain1more
Sep 23, 2010 02:19 PM
HarleyCorps
11
Mar 26, 2009 12:52 PM
Agnes the dog
Jan 25, 2009 11:50 PM
