Cam
Old Nov 20, 2011 | 10:05 AM
SGT89EVO's Avatar
SGT89EVO
Default Cam
Ok so here I go I never done major engine work Im mechanically incline And Ill have a manual to help with work. But I dont know much about cams I read post on here about EV27 seem good cams for my 89 flht but what are the pros and cons of this cam option I plain on do some major engine woek down the road will this be a good cam or do i have to go with adiffrent style (major engine work be go to larger engine then the 1340) If some one take a look at this cam set is it good thanks for the help
http://www.ebay.com/itm/Harley-David...item1e6871ccea
Old Nov 20, 2011 | 02:56 PM
Spanners39's Avatar
Spanners39
EV27 or 46 are both good, if you wanna increase a 1340 in capacity you will have to go the Stroker Kit path and if that is imminent I would go for the 46 but the 27 is also gonna work....it just depends on whether you are obsessed with numbers (as some seem to be) or if you know your riding style and have an understanding of where you want your power to be.
I tune Harleys as a side line but on my own bike I just have a K&N, debaffled pipes and an EV27....if and when I ever take the heads off they will go to Hans Gurau for a head and valve job.....that is really it.
If I had two bikes one would be an FXR with a Stroker Kit...but it wouldn't be my daily ride.
Old Nov 20, 2011 | 03:12 PM
SGT89EVO's Avatar
SGT89EVO
o ok yea i look into that step just trying to get alittle bump in power dont really care to much about number just want reliability i havent ridden this new bike yet still oversea so cant wait to get back try it out before i rip into it
Old Nov 20, 2011 | 04:19 PM
RidemyEVO's Avatar
RidemyEVO
I'm running a HQ rumble stick and at 3 grand she pulls real hard. Your going to get your biggest bang for buck with an ignition, cam and tuned carb as well as a good exhaust.
Old Nov 20, 2011 | 05:25 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Not sure how far in the future you are doing the engin mods but the 27 will give it all the power you need for everyday riding.
Old Nov 20, 2011 | 05:28 PM
dan1911's Avatar
dan1911
EV-27 is a good cam, if your mechanically inclined a cam is easy to install. It really depends on what your planning to do engine wise, and how far down the road?
Old Nov 20, 2011 | 08:00 PM
RHillbilly's Avatar
RHillbilly
Have you looked at the woods cams
Old Nov 20, 2011 | 08:54 PM
EVOrider's Avatar
EVOrider
Yea, I also like the EV-27 as well.....having said that, I also rode a Road Glide with the SE-3 and couldn't tell the difference between the two cams.
Old Nov 21, 2011 | 07:02 AM
grbrown's Avatar
grbrown
You will find a lot of fans of the EV27 on here. There are no down sides to it, just get on and install it, you won't be disappointed!
Old Nov 21, 2011 | 08:36 AM
rivercityslim's Avatar
rivercityslim
+1 Wood 6 is what I have in mine.
