evo cam change question
Old Jan 21, 2012 | 08:39 AM
RHillbilly's Avatar
RHillbilly
Arr those pushrods the ez install
Old Jan 21, 2012 | 09:34 AM
PanHeadRich's Avatar
PanHeadRich
Originally Posted by JohnFlorida
Ordered all the parts yesterday
EV 27 cam
torrinton bearing
andrews adj chromoly pushrods
metal breather
oem tappet lifters
all new gaskets ,seals, orings
tappet block alignment tool
Only thing I should need are shims and puller and I'll wait until I'm into it
Everything together was arouind $500 , not bad at all.
As soon as everything gets here I
m good to go
Please keep us advised. I'd be interested in hearing your opinion on what these mods do for the bikes permormance. I'm interested in doing the same mods to my stock 97
Old Jan 21, 2012 | 10:27 AM
JohnFlorida's Avatar
JohnFlorida
No wont need them if i remove tappets and blocks. They are adjustable
Old Jan 21, 2012 | 11:05 AM
dan1911's Avatar
dan1911
You will still need ez install pushtubes if you're not removing the rocker boxes. Installing new tappet blocks has no effect on how short the pushtube will need to be made to get it in. (pushtubes or pushrods refer to the same piece.)
Old Jan 21, 2012 | 12:42 PM
JohnFlorida
I'm pretty sure the andrews will work. HD adjustables dont
Old Jan 21, 2012 | 01:23 PM
Lakerat's Avatar
Lakerat
It was kinda like shoving a wet noodle up a wildcat's ***, but I did it on mine. Lots of pieces have to go in as a loose assembly, but if you take your time and think it through, it can be done. It did take me 2 attempts on the first one before I had enough parts stacked up.
Old Jan 21, 2012 | 01:27 PM
RidemyEVO's Avatar
RidemyEVO
The easy installs are the way to go NOT the normal adjustable ones. Just curious about the tappet block alignment tool , when I take my tappet blocks off I just reallign acording to where the bolts go in the holes.
I checked out your sig pics, beauty bike, I got my wife a a 89 heritage last fall and stripped it down, she didn't like the bags and carry rack. Where did you find the leather fender bib? Or any idea what there called?
Old Jan 21, 2012 | 02:08 PM
JohnFlorida
If I remember right it was a mustang fender bib with studs
Old Jan 21, 2012 | 02:10 PM
JohnFlorida
Yeah thats what I was thinking. If worse comes to worse I'll just pull the rocker boxes. Didn't want to go with the EZ's cause I heard there can be a noise problem due to thickness
Old Jan 21, 2012 | 03:01 PM
RidemyEVO's Avatar
RidemyEVO
Thanks for the tip, wifey will be happy, I hope.
