evo cam change question
Old Jan 19, 2012 | 08:23 PM
JohnFlorida's Avatar
JohnFlorida
Default evo cam change question
Ordering parts to change out my cam in my 97 flstc
Andrews EV27
torrington b138 cam bearing
se adjustable pushrods chrome molt 17900-87
nose cone gasket
.050 , .055 .060 cam shims
Am I missing anything?
Thoughts?
Old Jan 19, 2012 | 09:35 PM
Spanners39's Avatar
Spanners39
Breather shims are often not too flash if its a high milege bike but you'll need to measure your old one before ordering and you'll need new pushrod tower O rings too.
Old Jan 19, 2012 | 09:38 PM
Lakerat's Avatar
Lakerat
I would suggest ordering 2 identical gaskets. Use one (over and over if necessary)while checking your end play clearance, and save the uncrushed one for final assembly.
I think you're gonna like the 27.
Old Jan 20, 2012 | 04:50 AM
piperbob's Avatar
piperbob
Change the lifters while your in there. Heritage is a heavy bike. An EV-13 would be a better choice, that's what I have.
Bob
97 Heritage
Old Jan 20, 2012 | 05:31 AM
Doug S's Avatar
Doug S
I'd do the nosecone oil seal while it's off and probably the lifters if they have never been done. Many folks switch to a metal breather as well.
D
Old Jan 20, 2012 | 05:41 AM
JohnFlorida
Thanks everyone all good points.
Bike is low mileage picked it up last year with only 32K
I think the 27 is the way to go. Bike has been lightened a bit since I got it. See pics on profile.
I had planned on switching out the breather forgot to list
Old Jan 20, 2012 | 06:21 AM
JohnFlorida
Will I be able to change out these pushrods without taking the rocker boxes off or will I need to quick installs?
What about using a reed valve vs breather gear?
Old Jan 20, 2012 | 08:41 AM
HarleyGyrene's Avatar
HarleyGyrene
Smile
97 Heritage
Yep. Change the lifters. I also just used the EV-27 in my '97. This the 2nd one in 72,000. Not much wear but replaced it, the lifters, push rods, etc.
I think you'll like the EV-27, but everyone has their opinions and results.
Old Jan 20, 2012 | 03:14 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If you aren't going to take off the rockerboxes you have to cut the old pushrods to remove them and then put in ez-install ones.
Old Jan 21, 2012 | 07:43 AM
JohnFlorida
Ordered all the parts yesterday
EV 27 cam
torrinton bearing
andrews adj chromoly pushrods
metal breather
oem tappet lifters
all new gaskets ,seals, orings
tappet block alignment tool
Only thing I should need are shims and puller and I'll wait until I'm into it
Everything together was arouind $500 , not bad at all.
As soon as everything gets here I
m good to go
