voltage regulator pin replacement
Old Jan 27, 2012 | 10:15 PM
topfuel7's Avatar
topfuel7
Default voltage regulator pin replacement
Bottom pin on the voltage regulator cable plug had some corrosion on it and it broke while trying to get it off the stator plug. Does anyone know if there is a fix or maybe a kit that you can cut the end off and splice on a new plug?
Old Jan 28, 2012 | 06:22 AM
bigtone's Avatar
bigtone
I had a few burn the pins off due to oil weeping thru the stator plug on a couple of my bikes over the years. I never found any type of repair kit, and got tired of replacing good regulaotrs because of the plug. I found some 3 prong extension cords where the ground pin was a perfect diameter to fit in the stator plug. I bent the pin 90 degrees to fit inside the regulator plug, and crimped it to hold the wire. Been working for years, and I think it fits better than the original.
hardheaded
Mar 11, 2016 04:15 PM
nolabel
Jan 27, 2015 06:03 PM
Motorbulldog
Apr 4, 2013 07:27 PM
2/3cav
Aug 18, 2011 12:10 PM
fastball44
Electrical/Lighting/Alarm
Nov 4, 2010 07:52 AM
