Wide glide question
Old Feb 27, 2012 | 07:52 AM
FXD_One's Avatar
FXD_One
Default Wide glide question
Are the late 90's 41mm FXST and FXDWG front ends the same? From what I can find they are, but would like clarification.
Thanks
Old Feb 27, 2012 | 07:58 AM
bikerlaw's Avatar
bikerlaw
The triple trees are not the same on the Dyna and Softails. So they don't just bolt from one to the other.
Old Feb 27, 2012 | 10:58 AM
Doug S's Avatar
Doug S
If you look at my signature pic you will see the passing lamps that clamp onto the tubes, they are a Harley kit. When I bought them they had two listed, 41mm for FX softails and 39mm for FXDWG's...I don't remember the model years for each...
Doug
Old Feb 29, 2012 | 02:15 AM
blair's Avatar
blair
I believe 41mm FXDWG trees have 3 degree"s of rake in them .
Old Mar 1, 2012 | 07:31 AM
FXD_One's Avatar
FXD_One
Doug
Is this correct?
I believed it was 39mm tubes for FXD and Sportsters ( same front end ) and 41mm for FXDWG?
Also, was talking to a buddy ( has the exact same bike as mine, year, colour, everything ) and he has switched to a wide glide front end and added some rake. Is it nessisary to add rake when switching to a wide glide or can I leave it at zero rake? What are the Pro's and Con's to adding or leaving the rake?
Thanks in advance.
Old Mar 1, 2012 | 03:35 PM
tony g's Avatar
tony g
the FXDWG and the FXWG both have 41mm tubes, i have a set of FXDWG yokes ( with 3 degree rake ) on my dyna with FXWG forks.
jqb12
Feb 17, 2017 08:12 PM
Ink83
Aug 19, 2014 08:32 AM
sothai
Dec 3, 2012 05:29 AM
Dr Matt
Sep 3, 2011 08:57 PM
dglide
Dec 19, 2006 07:01 PM
