Fxr El bruto
Old Mar 6, 2012 | 01:09 AM
1989 fxr's Avatar
1989 fxr
Default Fxr El bruto
I ordered my new engine and clutch for my fxrhope that it lasts. I should have it in and running soon. I will post and let you know how it turns out. I ordered "113 CI -- Bore: 4.000", Stroke: 4.5", Piston: Forged, Compression: 10.2:1, Rated Power: 120RW Horsepower, 120 LB FT Torque, Camshaft: 264 Duration .625" lift, Pushrods: Crane, Valve Spring: Ultima, Chrome Nose Cone / Rocker Boxes, Billet Oil Pump, Chrome Tappet Blocks."
Old Mar 6, 2012 | 05:32 PM
bikerlaw's Avatar
bikerlaw
Wow! Like freakin..... WOW!!! I am so jealous. Keep us updates with reviews and pictures.
Old Mar 6, 2012 | 05:38 PM
Tom84FXST's Avatar
Tom84FXST
I seriously looking at those...keep us posted.
Old Mar 6, 2012 | 08:35 PM
miacycles's Avatar
miacycles
It should make you very happy, nive engine. What carb comes with it??
Old Mar 6, 2012 | 09:21 PM
1989 fxr's Avatar
1989 fxr
MIKUNI HSR45 and ultima ignition comes with the engine.The truck should be here any day I will post pic asap.
Old Mar 7, 2012 | 06:05 AM
miacycles's Avatar
miacycles
Leave the jets that come in the carb alone to start, raise the needle one notch and be sure to break it in according to the instructions. Before you start it the first time pull the plugs, run a jumper to the solenoid impulse wire and turn the bike over for 10 seconds, wait to ensure the starter doesn't overheat and repeat as needed untill you have oil pressure. Then do it five more times. This will ensure all moving parts have lube on them. By using the jumper you do not have power to the ignition which can damage it without plugs being attached, you could also do this before you attach the power wire to the coil. If you have some lifter noise PM me and I will suggest an easy fix. Hope this helps.
Old Mar 7, 2012 | 09:03 AM
Rynb15's Avatar
Rynb15
thats will be awesome with that motor in there.
Old Mar 7, 2012 | 10:33 AM
1989 fxr's Avatar
1989 fxr
Thanks for the info I downloaded the manual. it told me to do that one time but i like the way you said to do it five time need oil to the top end before starting. As an auto tech i always prime a new engine before starting but this is my first bike engine. I did not know how long to get oil to the top.
Old Mar 7, 2012 | 11:25 AM
C.H.L.'s Avatar
C.H.L.
SSSSWWWWWEEEEEEETTTTTTTT!!!!! I want one too!!! I'm probably looking at the 107, but it will probably a couple years
Old Mar 7, 2012 | 12:52 PM
2006FLST's Avatar
2006FLST
Wow can't wait to see the pics. Every time I think of doing head work and a big inch kit I figure I can just get a 107 and then sell my motor.
