Rear Wheel Alignment
Old Mar 15, 2012 | 08:31 AM
miacycles's Avatar
miacycles
If it's hitting when you go around corners then you have a bearing problem. Either the bearing and/or race are worn or there is too much end play.
Old Mar 15, 2012 | 04:22 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by traildog
I found that the sprocket on Bertha is rubbing the frame when I make a turn.
It looks like the wheel might not be quite straight.
How do I confirm and adjust that?
Didn't you just space it out so the belt will miss the tire?
Old Mar 15, 2012 | 07:18 PM
traildog's Avatar
traildog
Bingo! Took the wheel off tonight and the bearing is shot........
Old Mar 16, 2012 | 06:52 AM
miacycles's Avatar
miacycles
When you put the new bearings in be sure to check the end play, and get yourself some good synthetic wheel bearing grease. Don't forget to put a little lube on the inside of the seals too.
Old Mar 16, 2012 | 09:19 AM
98glider's Avatar
98glider
I just noticed on my super glide 98 that the tire is not center of the rear fender checked the measurement on the axle to the swing arm everything looks good and cannot figure what is goining on. I did put a new tire on her last year and the dealer installed the tire and installed new bearing,but I installed the back tire myself and just noticed the she is not centered. Do you guys think that the races are off Thanks
Old Mar 16, 2012 | 09:44 AM
miacycles's Avatar
miacycles
Some HD's have the rear wheel offset from the factory like .200".
Old Mar 16, 2012 | 10:15 AM
98glider's Avatar
98glider
I would have noticed before I am the original owner of this bike over 38,000miles thanks
skeetb1100
Apr 29, 2019 11:18 AM
njmcbldr
Mar 3, 2010 03:13 PM
Just Don
Wheels/Tires
Jan 20, 2010 08:01 AM
smudge
Oct 4, 2007 07:31 AM
ultravista
Aug 13, 2006 10:22 PM
