Wheel Alignment Questions
Old Jan 19, 2010 | 07:54 PM
Just Don's Avatar
Just Don
Default Wheel Alignment Questions
OK, I'm curious about the consequences of the rear wheel not being perfectly aligned with the front wheel. What happens when it's not right? Tire wear, I would suppose. Tracking? Any tricks for checking the alignment?
I guess my biggest question is does the alignment affect the position of the forks in relation to the rest of the frame while in motion? Visually on my Heritage it looks like my front forks are cocked to the right slightly while riding. I don't notice any drivability problems, it's just visually annoying. And it's not just the handlebars, it's the whole front end when viewed looking down at the front of the gas tank. Many thanks to all.
Old Jan 19, 2010 | 08:37 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Exclamation
Yes, alignment does affect position of forks...
To validate if the bike is out of alignment, get 2 long flourescent light tubes... this will tell you if the wheels are out of alignment... In the Service manual, it will explain the spec's and how to do it CORRECTLY...
Old Jan 20, 2010 | 04:04 AM
grbrown's Avatar
grbrown
Having owned Harleys since the 70s I always had my own system involving a lot of string! When I had a new tyre fitted a couple of years ago and before I put the wheel back in, I noticed the clearance between the edges of the tyre and the belt track in the pulley. In my case that was 3/16" and I now install the wheel so I have that clearance between tyre and belt. I use a 3/16" allen key as a 'feeler' gauge! Much simpler, assuming the rest of the bike is straight! Here in the UK we have to get our vehicles checked each year and mine has passed wheel alignment with flying colours.
Old Jan 20, 2010 | 08:01 AM
rbabos's Avatar
rbabos
I've covered this many times. Some softails have the rear wheel offset to the right up to 1/2". Most have the front wheel offset to the right about 5/16" Due to belt tracking you will never get the two to follow the same path due to this and the fact the bike will be heavier on the left side. This requires a slight right tilt going down the road and a slight right input with the bars. I've moved that ***** of a 200 all over the place and have never found a spot where it will not drift left when taking my hands off the bars. Never , I say. Mainly because of the left heavy of bikes centerline. My bike is an 07 fxstc. Newer models have the rear wheel in the center now. Geeze, I wonder why?
Ron
skeetb1100
Apr 29, 2019 11:18 AM
Rain
Sep 25, 2013 10:03 AM
traildog
EVO
16
Mar 16, 2012 10:15 AM
Mrrick
EVO
Sep 22, 2010 02:52 PM
ultravista
Aug 13, 2006 10:22 PM
