rear caliper
Old Apr 1, 2012 | 06:46 PM
Mountainkowboy's Avatar
Mountainkowboy
if your talking about the cup that pushes on the pad, open to the pad, flat to the caliper. Otherwise it would take ALOT of brake fluid to bleed out with a giant void towards the caliper. Would probably NEVER get all the air out.
Old Apr 1, 2012 | 07:10 PM
RidemyEVO's Avatar
RidemyEVO
Nope not the one I'm talking about. I'm referring to the master brake cylinder. The rear brake pedal pushes on its innerds to make the brake pads work.
I'm thinking I need a new one, I put it all back together and its seeping a bit, I noticed last year it was wet there and thought it was coming from some where else.
Also if someone can give me the oem number for the rear master brake cylinder.
Old Apr 1, 2012 | 08:18 PM
Dr.Hess's Avatar
Dr.Hess
Well, my '86 uses a 41755-86 Master Cylinder. The rebuild kit is a 42374-86. That's probably all you need.
Old Apr 1, 2012 | 09:56 PM
RidemyEVO's Avatar
RidemyEVO
Thanks Dr Hess, what warrants a new rear brake master cylinder compared to just using the rebuild kit?
Old Apr 2, 2012 | 07:33 AM
miacycles's Avatar
miacycles
Flat part of the rubber cup goes against the piston in the master cylinder.
Old Apr 2, 2012 | 08:53 AM
RidemyEVO's Avatar
RidemyEVO
Perfect thanks John. Is there any special trick to installing the kit?
Old Apr 3, 2012 | 09:57 PM
RidemyEVO's Avatar
RidemyEVO
Kit came today and I installed it and bled as much of the old fluid out as I could. I also through in some new pads so I shall see how it works out.
spike95
Sep 7, 2014 08:06 PM
relli
Aug 19, 2013 02:55 PM
glidingwide
Nov 15, 2010 11:08 AM
Silver Fox
Jul 3, 2010 10:32 AM
Old Texas Gringo
Feb 25, 2008 04:50 PM
