what changed from 89 early evo to 90 plus?
Old Mar 29, 2012 | 09:43 PM
pauliespringer89's Avatar
pauliespringer89
6th Gear
Default what changed from 89 early evo to 90 plus?
I own an 89 springer softail, see so much stuff available fr later evo models, but getting rare for early..what changes were made?? seems to be gear box , primary changes etc..but what were these changes?
Old Mar 29, 2012 | 10:19 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The transmission main shaft got splined. The clutch hub changed to fit transmission shaft. Starter solenoid moved from inner-primary to starter. Inner and outer primary got a design change. The motor changed from a bottom breather to a top breather.
That is all I can think of right now.
Old Mar 29, 2012 | 11:52 PM
Bama91's Avatar
Bama91
Starter jackshaft changed, Many ring gears went from weld on to bolt on. After 1984.5 clutch pushrod changed it seems every other year.
Old Mar 30, 2012 | 03:59 AM
badcooky's Avatar
badcooky
Engine breather,oil filter set up,carb,some plumbing and other **** too.
They got more expensive.
Old Mar 30, 2012 | 04:07 AM
Tom84FXST's Avatar
Tom84FXST
89 was also a transition year and changes were made mid-year...so somethings may or may-not fit depending on the date it was made. The springer itself changed in 93?... went to the lower fender mount
Old Mar 30, 2012 | 05:04 AM
grbrown's Avatar
grbrown
Red face
I think that happened later? Early 90s, not 90.
Old Mar 30, 2012 | 07:11 AM
gsxrboy96's Avatar
gsxrboy96
I believe 1993 was first year for the head breather ...
Old Mar 30, 2012 | 05:55 PM
polish hammer's Avatar
polish hammer
got a 92 evo motor will it fit in an 1987 softail?
will i havya change the primaries??
Old Mar 30, 2012 | 08:29 PM
Ultra89Rider's Avatar
Ultra89Rider
The 1989 bottom end motor is a "One Year Only" Motor. Before 1989, the crank was made of 5 pieces. The two pinion shafts, two fly wheels and wrist pin. In 1989 Harley attempted to make the manufacture less expensive and cast the pinions with the fly wheels. They were the same diameter. Problem was that the original pinions were Case Hardened. It was not cost effective to case harden the entire Fly wheel. So they just "Surface hardened" the pinions. This proved OK in the testing, but under regular use, they found that under long term and hard use, they would fail. So beginning with the 1990 model year, the shaft was enlarged and the cases were changed to accommodate the larger pinion. This was not classified as a Safety Issue and not subject to a total recall. For Harley to issue a complete recall for all 1989 BT model motors would have cost Harley a large amount. And as it only would effect those that subjected their Harley to heavy usage, they only issued a "Service Bulletin" to cover only the original owner and under warranty, or close to the end of warranty. It saved Harley a lot of money.
If you check the Harley Part Catalogs for 1987-1990 (I have it along with one issued in 1989) any motor part using the "-89" part is obsolete. It has been replaced with the "-90" part.
Old Mar 31, 2012 | 06:59 PM
polish hammer
nice info
