Engine seal help.
Old Mar 29, 2012 | 11:43 PM
Bama91's Avatar
Bama91
Default Engine seal help.
Anyone know the OEM # for the front (engine, left side) oil seal? The one that goes behind the stator. When I look it up I either get 971 different items or one that I can't tell from the pic if it's the engine oil seal or the transmission oil seal as both are labeled main shaft oil seals. I believe it is this one : https://www.denniskirk.com/genuine-j...prd/H14206.sku but not sure. J&P has them but since they are S&S I have to wait and call or the price. DK says the OEM # is 12013A.
My bike has been sitting with the primary off for 6 months and fluid is still coming out from behind the stator plate. Thought at first it was primary fluid weeping out, but after 6 months it should be bone dry.
Old Mar 30, 2012 | 02:26 AM
badcooky's Avatar
badcooky
Yep that looks like it.
It's the sprocket shaft seal outside the sprocket shaft spacer in Harley speak.
Face it inwards it can go both ways,they seem to work better if placed for a belt drive.
If it's leaking out there,there's a lot of oil in the cases,your check ball valve needs looking at.
badcooky's Avatar
badcooky
Old Mar 30, 2012 | 07:10 AM
Bama91's Avatar
Bama91
Thanks. In some books the transmission seal is also called the mainshaft oil seal. I wish they could get just a little more vague.
Old Mar 30, 2012 | 07:30 AM
Bama91's Avatar
Bama91
That wasn't it, but I found the correct one. Looked it up in the paper catalog that actually shows a diagram.
Old Mar 30, 2012 | 07:48 AM
Bama91's Avatar
Bama91
This is it : https://www.denniskirk.com/genuine-j...prd/H26251.sku
OEM#12026B In case anyone needs the number. Dennis Kirk says it won't fit but the book says it's for a 1970-1999 Big Twin. Mine's an 88 motor, so it falls in that category.
86evokid
Engine Mechanical Topics
Jun 21, 2018 07:56 AM
Bill wallace
Shovelhead
May 16, 2017 05:43 PM
Philphy
Feb 24, 2014 07:43 PM
HB
Shovelhead
18
Sep 9, 2012 08:09 PM
83ironhead
Oil Archive (no new posts)
Sep 11, 2005 10:32 AM
