Speedometer Problem
Old Apr 14, 2012 | 09:53 AM
nocoast's Avatar
nocoast
Default Speedometer Problem
I have a 1990 Heritage. The other day the odometer and tripometer stopped working. The speedo still indicates correct speed. If I get to about 70mph the odometer/trip will start to turn but are not accurate.
Any ideas? I don't want to buy and aftermarket speedo cause I'd like to keep the original miles. Could it be a cable issue or is the problem in the speedo?
Old Apr 14, 2012 | 11:55 AM
Dr.Hess's Avatar
Dr.Hess
Problem's in the speedo. There are some rebuild shops.
Old Apr 15, 2012 | 08:00 AM
grbrown's Avatar
grbrown
When you get down to the basic mechanism inside they are very simple. The trip and mileometer mechanism is probably prone to clogging up with dirt after a lot of years. May only need a good clean, failing that follow Dr Hess's recommendation.
Old Apr 15, 2012 | 09:17 AM
Tom84FXST's Avatar
Tom84FXST
http://www.speedometersolutions.com/...ter_repair.htm
Old Apr 15, 2012 | 11:21 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I'm not sure about your '90 Heritage but my '95's speedo is a non-reparable unit.
I'm having problems with the lights in mine so I did some research and the manual and the dealership both say you have to replace a malfunctioning speedo.
Old Apr 15, 2012 | 11:28 AM
Tom84FXST's Avatar
Tom84FXST
The dealership can't/won't....but a speedometer shop can repair it. Most speedo's require special tools to dissemble/reassemble it without damage...so most people can't do it even if it just needs cleaning/oiling.
Old Apr 15, 2012 | 11:32 AM
texashillcountry
Dirt don't hurt
Then why does the '95 manual tell me it is designed as a non-reparable unit?
(No sarcasm intended just asking)
Old Apr 15, 2012 | 12:31 PM
Owtlaw's Avatar
Owtlaw
I've "serviced" a lot of stuff that said "no user serviceable parts inside". Results have varied pretty widely.
Old Apr 15, 2012 | 07:50 PM
nocoast's Avatar
nocoast
Thanks for the advice guys. I'll try and is if I can get in it first. I think the 90 speedo is the same as the 95. I found a speedo repair shop online and when I called they said they couldn't qoute a price without looking at it.
Old Apr 15, 2012 | 07:56 PM
texashillcountry
Dirt don't hurt
A new one from the local dealer is $167 and change.
bigsteve799
Sep 21, 2023 12:05 PM
Dkknight74
Electrical/Lighting/Alarm
Jul 7, 2021 09:54 AM
coola
Jun 19, 2012 02:16 PM
munch34m
Jul 31, 2011 08:49 AM
kyote
EVO
25
Jan 18, 2011 06:42 PM
