Early FXR starter problem--need advice
Old Jan 9, 2020 | 09:17 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Nukin’ Harley
Hey y’all!!! I changed the battery with a scorpion battery that is rated for 310CCA and it turned right over!!! Now it’s running and I took it for a spin and the clutch didn’t have any tension after less than 5 minutes of driving. Now onto the next problem... starts up first time every time!!
Glad you got it sorted out but I gotta ask what battery did you put in it that didn't have enough CCA to spin your starter?
Old Jan 11, 2020 | 09:00 AM
Nukin’ Harley's Avatar
Nukin’ Harley
5th Gear
Installed an Advance Auto battery that had 260CCA when OEM is 280CCA. The real issue is that it’s a power sports battery from advance auto. They sit on the shelf for at least a year sometimes longer which in my experience thus far typically means they’ll be bad.
Old Jan 11, 2020 | 09:34 AM
Racepres's Avatar
Racepres
Sure is alot of misinformation about the early [5-speed] Starting system... much like the BS about the old Shovel System...
Good Battery, Good Cables... Sound Connections... Never a Problem...and I run one of the Cheapest AGM Battery I can find..
Got a fairly High Compression '93 EVO in my '83 Chassis and drive train... I can tell when the battery is getting Weak, because I need to put it in 3rd or 4th gear, roll it backwards a bit, then Neutral and Hit starter... gotta give it a head start... then ... New Battery time... Generally about 3 Years...
HD47knuckle
Shovelhead
Jun 8, 2013 06:43 AM
sixty7flh
Shovelhead
Jul 14, 2010 06:41 PM
Knuckle Sandwich
EVO
Jun 15, 2010 06:56 AM
traxsmax
Ironhead
Aug 31, 2006 11:15 AM
slugbug
Ironhead
Jul 15, 2006 11:27 PM
