Heat cycle? Warm up time? Enrichener?
Old Apr 27, 2012 | 08:30 AM
petewerner's Avatar
petewerner
My 1998 Fat Boy is basically a stock motor with 40K miles and I have always used the enrichener when needed to get it started when cold. Then I jump on and run the crap out of it. I have Bub7 2-1 and a single fire ignition/coil set up, nothing else done, never even had the heads off.... Seems like the Evo let's me run well all the time, but my 11 twin cam is a much refined drive system VS the 98 Evo... What enrichener? EFI is a much better way to go
Old Apr 27, 2012 | 08:44 AM
rivercityslim's Avatar
rivercityslim
I use the enrichener to start the bike, but shut it off within seconds and use the throttle lock to adjust rpm's. I usually let it warm up until the rear rocker box is warm to the touch.
I bought a cool little gizmo a few years ago that makes using the throttle lock easier - Throttle Mate. Maybe the best $15 I ever spent. Here's a pic:
Old Apr 27, 2012 | 09:10 AM
2006FLST's Avatar
2006FLST
Wow I got to get one of those. Thanks for the link.
Old Apr 27, 2012 | 09:12 AM
ILLEGAL REGAL's Avatar
ILLEGAL REGAL
Enriched to start then throttle lock for a few minutes
Old Apr 27, 2012 | 09:22 AM
D1gger's Avatar
D1gger
Okay, so what is a "heat cycle" then?
Old Apr 27, 2012 | 09:27 AM
MJ's Avatar
MJ
I use the enrichner the same way. Just long enough to start it. I wait until I start feeling the heat on my legs.
The throttle mate is handy. I have had 2 of them, but have lost them both. I kept hitting them with my fingers and knocking them off. Maybe I did not tighten them enough, but I did not want to break that old star.
Heat cycling usually refers to prepping a new or rebuilt engine by running a short duration and cutting it off to cool. Then running a little longer and letting it cool, repeat
Old Apr 27, 2012 | 01:08 PM
rivercityslim
I've had the same one for about three years now with no issues. I occasionally use it while on the road also if I need to take my hand from the throttle for a few seconds for any reason.
Old Apr 27, 2012 | 02:40 PM
bparsel's Avatar
bparsel
Wow, I opened this thread expecting a bunch of "Let it fully warm up before you take off" ...Im actually surprised at the responses!
I'm pretty much the same as everyone else I guess. It was 32 degrees when I left for work this morning, I rolled the bike out, flipped on the choke and fired her up. Put on my helmet etc. and proceeded out the driveway. I short shift for the first mile or so and work the choke off. Bike doesnt seem to mind at all, and I actually like my neighbors!
Old Apr 27, 2012 | 03:20 PM
wheel752's Avatar
wheel752
Turn the choke off immediately. Extra gas on cylinder walls, washes off the oil...
I have head temp gauge, warm up to over 200 degrees. Takes awhile... Then ready to go.
Old Apr 27, 2012 | 05:08 PM
schwangster's Avatar
schwangster
+1
Evo threads are always full of surprisingly great info!
