Heat cycle? Warm up time? Enrichener?
Heat cycle
http://www.sscycle.com/techtips/tech...p?x_catagory=4
Hastings ring procedure
http://www.hastingsmfg.com/ServiceTi..._procedure.htm
Attached some reading information below that adds another view to engine breakins, Engine breakin can be a very contraversial subject.
http://www.mototuneusa.com/break_in_secrets.htm
After all the reading it came down to: don't let it idle for extended periods, vary your speeds and rpms on a straight stretch, apply loads without lugging, close the throttle fully when deacellerating, don't go past 5500 rpms, NO SYNTHETIC OIL FOR 5000 MILES, multiple oil changes during the breakin period.
We use a full load, no idle breakin with massive diesel engines, heat is needed to seal chrome moly rings which is current in Harley engines.
On a Harley I've followed the S&S heat cycle method before and looks they are just trying to build heat at initial breakin, on my current engine that has a looser piston fit, built up some heat without idling and ran it like any other day of riding.
Do your homework, choose a path, don't second guess yourself, don't be so uptight that you can't enjoy the new engine and ride the h$ll out of it, make it an enjoyable experiance.
This dude knows his ****......makes a lot of sense.
Harley sends the CVO bikes out from the factory with syn 3 in the bikes so using a synthetic oil for break in isn't detrimental.
Now syn oil is expensive and when breaking in a new engine you should change the oil at around 50 miles or so,then again at 300 or so,then again at 1000 miles or so. Frequent oil changes during break in will remove any potentially damaging shards of metal from the inside of your new motor,which,to me is a good idea. So since you should change it often it makes no sense to use an expensive syn oil just to dump it so quickly,but that doesn't mean you can't.
Heat cycles, accelleration, loading the engine is a method to seal a chrome moly ring by heat and pressure, synthetic oil is known to disapate heat so I can see why engine builders recommend not to use synthetics and all in theory of someone that does it for a living.
We all know Harley has made some mistakes; inner cam bearings, chain tensioners. scissored cranks, weak cases, over priced Tiawan chrome, I guess putting Syn3 in CVO's is an engineering marvel but that is a theory to constitute a 32,000 showroom Harley, imagine non-synthetic oil to a potential buyer at that price.
