Speedo Sensor Spacer
Old May 3, 2012 | 11:12 AM
cwhite6's Avatar
cwhite6
Default Speedo Sensor Spacer
I have a Ultima 6 speed transmission for my build. I am using a Dakota Digital bar mount speedo with their speedo sensor. The instructions for the speedo sensor say to use a spacer supplied with the transmission for the sensor. Mine did not come with a spacer, also the Ultima has the sensor in a different place than stock. So, do I need one and if so where could i get one? Also, the sensor has an o ring on it about halfway down on the part that slides into the transmission. I could not get it to go in past the o ring? Do I just need to put a little assembly lube on it and push harder? Thanks.
Stiggy
Electrical/Lighting/Alarm
Oct 1, 2016 09:40 PM
19JMan70
Apr 11, 2014 06:03 PM
mays
Jul 28, 2008 07:12 PM
hammon
Jun 9, 2008 06:44 PM
emeraldbiker
Aug 14, 2006 10:32 AM
