Oil puke breather
Old May 19, 2012 | 06:32 PM
gnafin's Avatar
gnafin
Default Oil puke breather
well i got the oil puke from the breather. i have a 84 flhtc EVO. and it was ok last year but now when i start it i geet a big flow of oil out of my breather under the motor.... i did clean the check ball, but it still does it. and i am getting oil leak from my Primary as well. and this has a dry clutch, so it should just be a little oil...i guess i will change the oil and filter then see what happend.... any help?
Old May 20, 2012 | 10:27 AM
1997bagger's Avatar
1997bagger
You are still getting bypass from the check ball, the seal lip on the crank seal is made to to keep the primary oil out of the crankcase because oil is pulled out of the crankcase and not filled over the seal, if your oil tank is leaking into the engine it will fill past the crank seal and leak into the primary.
You should purchase a new check ball and seat it into the bore, read about methods of tapping the ball to seat it or using a Chevy push
tube with valve grind compound on the ball end and spin it on the seating area, havn't never had to do either so wait for a hands on member to help with the seating process.
Old May 20, 2012 | 10:32 AM
RidemyEVO's Avatar
RidemyEVO
As soon as I cleaned the little screen cap in mine it started flowing and eventually went down to a very small drip after stopping, I didn;t pull the ball out as I figured it would mess up the seal so obviously just pulling the cap will do the same thing. There is a couple remedy's out there for it, not sure where I seen it but taking a old push rod with some lapping compound to the end of the push rod ball end and lapping the seat of the ball and then replacing the ball is suppose to work.
Old May 20, 2012 | 12:24 PM
gnafin's Avatar
gnafin
Hmm little screen cap? where at?
Old May 20, 2012 | 01:11 PM
TwiZted Biker's Avatar
TwiZted Biker
Just posted this over in the shovelhead section , deals with the check ball problem .
https://www.hdforums.com/forum/shove...heck-ball.html
Old May 20, 2012 | 01:20 PM
Dr.Hess's Avatar
Dr.Hess
If you have a dry clutch, then, yeah, you probably need to check the lifter screen. Although, with a real oil filter instead of what shovelheads had, I would be curious to see if anything gets trapped in the screen.
Do not use a giant screwdriver on the plug. You WILL screw it up. They make a tool just for that plug. Get one of those.
Old May 20, 2012 | 03:02 PM
gnafin's Avatar
gnafin
is that screen in that plus next to the one with the spring and ball?
Old May 20, 2012 | 04:48 PM
RidemyEVO's Avatar
RidemyEVO
Yes screen , spring and ball.
Hector.m.carpio
Apr 29, 2019 03:35 PM
HMZHD41
EVO
11
Oct 18, 2013 03:06 PM
duallram03
EVO
Oct 13, 2013 08:19 PM
Dana Phelps
Feb 13, 2013 07:25 AM
whocares
Panhead
Jan 13, 2008 02:39 PM
