Oil pressure Switch
Old May 20, 2012 | 06:18 PM
Scudda's Avatar
Scudda
Default Oil pressure Switch
looks like I am seeping oil from the threads of my oil pressure switch on my 1995 FXDL. Does anyone know a trick to removing the switch with out having to buy the HD tool for it?
Old May 20, 2012 | 07:42 PM
Jethro's Avatar
Jethro
Well... I don't mean to be a smartass here, but yes, you can grab the thing with a pair of pliers and just wrench the crap out of it. A rag might make the pliers bugger it up less. One thing I will caution you on is that it is very easy to crack the case there where it threads in. So, check that there is not a crack there already when out, put it back in with a sealer ( I use the purple type...here is a link to the ones from Loctite... http://www.kraftindustrialsupply.com/gasket_sealant.htm). I have the tool but then I like to work on bikes a lot and it pays for itself...
Old May 20, 2012 | 10:37 PM
RidemyEVO's Avatar
RidemyEVO
Yes I beleive mine came out with a wrench, it is very close to the lifter block which makes it a pain.
Old May 20, 2012 | 10:38 PM
TwiZted Biker's Avatar
TwiZted Biker
Custom tool called channel locks
joe40x
Engine Mechanical Topics
May 10, 2017 07:11 PM
95softail
Apr 21, 2010 05:16 PM
95softail
Apr 21, 2010 04:32 PM
Fast Eddie
Feb 16, 2009 12:32 PM
Geordie Pete
Exhaust System Topics
Feb 4, 2009 12:35 PM
