check ball
Old May 18, 2012 | 07:42 AM
ralv2rd53's Avatar
ralv2rd53
6th Gear
Default check ball
76 fxe / someone told me about a trick to weld something onto a check ball then dip it into some type of solution and it will stop the oil from leaking out of the breather ..does anyone know about this and what the something and solution are ?
Old May 18, 2012 | 08:32 AM
panz4ever's Avatar
panz4ever
Problem on some of the old steel bodied pumps was a check ball that was not seating properly. What you did is take a steel rod and weld it to the end of the check ball, use a bit of lapping compound and turn it into the seat and create a better seat for the check ball.
Not sure the same solution would apply to an aluminum pump.
Old May 18, 2012 | 11:59 AM
TwiZted Biker's Avatar
TwiZted Biker
Use an evo pushrod the ball on the end is the same size exactly . You can just tap it a couple times LIGHTLY to seat or use a little lapping compound to gently lap in a seat . Only do this with the pump off so you can clean it thoroughly .
Old May 18, 2012 | 04:57 PM
panz4ever's Avatar
panz4ever
Thanks for the info Twizted....one more piece of knowledge to add to the books.
Old May 18, 2012 | 05:49 PM
TwiZted Biker
The brass bushing is a standard size any decent hardware should have 3/8"ID x 1/2" OD , helps center it when doing the lap . You bevel the edge a bit so it catches the first thread .
Old May 18, 2012 | 06:25 PM
AlCherry's Avatar
AlCherry
Love that pushrod idea. You learn something new every day!
fergerburger
Shovelhead
15
Mar 29, 2018 09:19 AM
TwiZted Biker
General Topics/Tech Tips
Jun 5, 2012 01:35 AM
hotrod351
EVO
Jul 20, 2011 05:05 PM
Mr. Wannabe
Shovelhead
11
Jul 19, 2011 07:04 PM
Bluto 67
Shovelhead
Jul 24, 2009 05:59 PM
