There she sits; All back together, shined up, fueled up and ready to fire up for the first time on the new engine as soon as my soon-to-be wifey gets home from work. I primed the oil pump already and the best part is that I have NO LEFTOVER PARTS except some old pieces that got replaced. I will report back in a little while how it turns out. Everyone PLEASE keep your fingers crossed for me! LOL!
The wifey-to-be came home and together we went to the garage. With one of us on each side of the bike; me on the right holding the throttle and right controls, her on the left holding the clutch, I turned on the fuel, pulled up the choke, twisted the throttle a couple times to get fuel to the carb, switched on the ignition and pushed the starter button...
I don't think it even did a full revolution before it roared to life. The remanned engine combined with the new twinkie take off exhaust gave a very pleasant end result. This thing super smooth, not too loud, yet still rumbly like a Harley should be. I quickly noticed that I had the oil pressure sending unit wired backwards, so before it got too hot, I swapped the wires around so I could keep an eye on the oil gauge. Nothing leaks, the charging system is charging like it should and the timing seems to be really close. I was afraid it might run rich since I lost the cam with the reman, but the exhaust seems just perfect, no smoke, no eye burning at all, just right.
I ran it through a heat cycle on the stand with a fan blowing across the engine, probably a good 10 minutes or so, then shut it down for the night. Towards the end of the ten minutes, the engine seemed to idle up a little bit, from 1000rpm up to about 1500 or so. Not sure why. After the first 50 mile break in run tomorrow, I plan to take it to the shop and have them double check the timing and carb settings.
I am SO happy right now! I can't wait to get back on it!
I got the job done faster than the first shop quoted me for roughly $1200 less than they were trying to gouge me for to boot. Feels good...
