Ignition Problem
Old Jun 18, 2012 | 04:37 PM
Jim Kraft's Avatar
Jim Kraft
OK; This is getting interesting. I would have thought you would have noticed a bad valve when you had the head off for the new piston work. I am guessing you did not check the compression before you did the work. That would tell you if it was bad before you tore it down. If not, I doubt it was a valve unless it got some foreign material under it when you had it down. Thank you for letting us in on this one, and please keep us informed. I love these mysteries.
Old Jun 18, 2012 | 08:43 PM
miacycles's Avatar
miacycles
It could also be a bent valve if you adjusted them wrong or didn't let them bleed down all the way before turning the engine over.
John
Old Jul 16, 2012 | 01:28 PM
okidiver2001's Avatar
okidiver2001
Just a last note to all. Thanks for the help. I pulled both heads, had a valve job done, new SE quick install adjustable push rods. She runs great and strong!!! I did have a burnt valve, and a leaking valve seat... Both were in the back head though.
D-Bag
Engine Mechanical Topics
Jul 17, 2014 09:21 AM
neverdown
Aug 8, 2012 07:45 PM
n.texan
Ironhead
Jun 21, 2011 09:33 PM
D-Bag
Electrical/Lighting/Alarm
Nov 13, 2010 08:45 AM
errasa
May 3, 2008 07:10 AM
