Is end play the amount the wheel will.move side to side?
If so, its corrected with spacers, or thin washers right?
There are shims available for that, I did my front a couple years back. Bascily you tighten the axles down tight light normal and lock it in a vice and get a guage same as you use for runout on a crank and check endplay.
I would just wait for a rainy day take the wheel off take the bearings out clean them and everything else in there Then you can check the bearings, races,spacers,shims
Then put it together on the bench dry no grease I check end play by feel it works for me
This way you will know what you need if anything
