Engine replacement choice
Old Jul 8, 2012 | 03:30 PM
TORQUEY's Avatar
TORQUEY
Don't forget Jims' 131 and 135...
Old Jul 8, 2012 | 03:39 PM
grbrown's Avatar
grbrown
Talking
Originally Posted by 1997bagger
GR, with a 131" the front end will be in the air and the front brakes will be extra weight
.........essential ballast!
Old Jul 8, 2012 | 04:03 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I'm not sure front breaks will be enough ballast.
You might need to put a 80 lbs bag of concrete on the front fender. LOL
Old Jul 8, 2012 | 04:55 PM
1997bagger's Avatar
1997bagger
Your way ahead of me GR
Old Jul 8, 2012 | 10:27 PM
monkeyboy22's Avatar
monkeyboy22
Originally Posted by Jim Kraft
.... He did have to beef up the clutch and the starter shortly after he started riding it. Well over 115 torque and horsepower.
I have an S&S 107" in my Glide and like Jim had to beef up the clutch.
How did you address the clutch? Whole new unit like this or upgrade just the plates and spring like this? [I'm not promoting SE, just trying to get an idea of what to expect.]
Old Jul 9, 2012 | 03:31 AM
grbrown's Avatar
grbrown
I used a Barnett spring on the stock clutch, everything else being my original 1990 parts. The increased torque is great to ride with, but not so much more that an entire new clutch is needed. I found the extra effort ruined my wrist and hand in traffic, so tried a couple of ways to reduce lever effort, finally going with a Diamondback clutch cable.
I have a set of Barnett +1 plates I plan fitting soon, although that is nothing to do with my motor, but looking for improved clutch action.
What I did change was the compensator and chain, because the teeth were getting sharp and the chain had detectable wear. Clutch and its teeth were fine.
Old Jul 9, 2012 | 04:00 PM
Jim Kraft's Avatar
Jim Kraft
My son started out with a hydraulic clutch from the begining, so his is fairly easy to pull. When you build your own you can do a lot of tricky stuff. His belt runs on the right side, and the pulley doubles as the brake disc. He had to machine his own triple tree's because his front end is so wide. Being a machinest helps.
grbrown
EVO
48
Jul 29, 2019 08:12 AM
nellis003
Exhaust System Topics
Feb 15, 2013 09:51 PM
Smokey Burnouts
Jan 13, 2010 10:52 PM
Kamil
EVO
13
Sep 19, 2008 04:43 PM
roach
22
Sep 7, 2006 01:41 AM
