pinion gear shaft size HELP!!!
Old Jul 14, 2012 | 09:16 PM
flh04087's Avatar
flh04087
Default pinion gear shaft size HELP!!!
I had a friend rebuild my 84 evo but i think they used the flywheels and pinion shaft assembly from a later model, i bought the pinion gear for a L77-89 BUT its very loose on the shaft i miked thepinion shaft and it aprox .632 inch can anyone tell me hat year parts i need to buy?
Old Jul 15, 2012 | 12:49 AM
TwiZted Biker's Avatar
TwiZted Biker
Is the shaft area where the pinion gear sits straight or have slight taper to it ? After 1990 they changed the pinion shaft from tapered to straight which is slightly smaller . There's a kit that corrects that check with a few of the bigger catalog suppliers .
You have to have this conversion kit can't just use a later gear , size difference and mixing will eat the gear train .
Old Jul 15, 2012 | 07:16 AM
flh04087's Avatar
flh04087
hey thanks for the reply my shaft (the one on the engine) haha is straight there isnt any taper?
is this what i need
http://www.ebay.com/itm/S-S-Cycle-Pi...17%26rk%3D1%26
Old Jul 15, 2012 | 09:32 AM
TwiZted Biker
That's the one but you need to make sure which gear color code your motor needs , there's 4 of them red , blue , yellow & black . It's a matched set kinda deal each is just enough different in size it will either whine like crazy or bind and chew the gear sets .
Your cam gear should have a color spot on it so match up , if not Red is the most common and black after that . J&P cycles list's them .
http://www.jpcycles.com/catalog/2012...?entrypage=486
Old Jul 15, 2012 | 05:35 PM
flh04087's Avatar
flh04087
the cam is the orignal cam from the 84 its got a green dot im sure i can use the same cam ?
Old Jul 15, 2012 | 08:14 PM
TwiZted Biker
Your going to need to hit the dealer or a local builder and ask . From here on it takes somebody who knows or has the specs on the actual sizes per color between the years and give you the match up . I can't say reliably without doing the measuring and math and won't give info I'm not 100% on , sorry man .
Old Jul 17, 2012 | 04:17 AM
flh04087's Avatar
flh04087
not a problem thx for your time bud, im gonna buy a new red dot cam something alittle bigger than stock, mid range maybe ,that will sort out the mesh/whine problem im sure
1964duoglide
May 8, 2018 04:28 PM
Mike Petrill
Apr 21, 2018 04:22 AM
bobsemp
Engine Mechanical Topics
Dec 22, 2017 10:32 AM
fdh161
Sep 24, 2014 12:35 PM
tc
EVO
11
Jan 9, 2011 03:47 PM
