Truing a spoked rim
Old Jul 31, 2012 | 08:16 PM
Spanners39's Avatar
Spanners39
Check fender bolts are tight, remove all balance weights and try again.
I had an Ironhead did this when I bought it and it just needed a few bolts in the fender mounts to pull it back into line :-)
Old Jul 31, 2012 | 08:27 PM
traildog's Avatar
traildog
Fender bolts? Are you messing with me?
I said it once and I'll say it again.....I DON'T do LSD!
Old Jul 31, 2012 | 09:24 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by traildog
When I start moving on Bertha, it feels like the front wheel is wobbling. The bars even move a bit.
Sounds like the wheel is out of round, right?
What else might cause it?
Sweep the garage floor and try again.
Old Aug 1, 2012 | 01:04 AM
Spanners39's Avatar
Spanners39
Not at all, the fender acts as a fork brace.
Old Aug 1, 2012 | 01:41 AM
oppirs's Avatar
oppirs
Did you make tho spokes sing>?
Old Aug 1, 2012 | 01:55 AM
akmorris81's Avatar
akmorris81
Try tightening your riser clamps. I had a shovel that my risers came loose, wasn't visible to the eye but was able to tighten and same problem your having went away
Old Aug 1, 2012 | 06:52 AM
traildog's Avatar
traildog
Yep. Tapped on all of them and they all sounded exactly the same.
Old Aug 1, 2012 | 06:57 AM
traildog's Avatar
traildog
I KNOW you're messing with me!
Old Aug 1, 2012 | 09:00 AM
texashillcountry
Dirt don't hurt
Yep
Sorry I couldn't help it.
Old Aug 1, 2012 | 12:03 PM
Schex's Avatar
Schex
Wouldn't hurt to check the pinchbolts on the lower tree.
