Timing Question
Old Jul 31, 2012 | 10:46 PM
lieutenant G's Avatar
lieutenant G
Default Timing Question
I have a general idea of what timing adjustments do, however Im curious why one would want to adjust their timing. Iv always marked where it was when I had to go into the came case and never thought much about it. I have ported heads, bored cylinders, new pistons and a I just put a new cam in yesterday. any reason why I would want to adjust? Anyone want to give my a fairly educated explaination of timing with regards to our Evo motor.
Just trying to learn something new here. Thanks
Lt.
Old Aug 1, 2012 | 12:10 AM
ILLEGAL REGAL's Avatar
ILLEGAL REGAL
Timing is everything!
Old Aug 1, 2012 | 01:09 AM
Spanners39's Avatar
Spanners39
If you changed the cam the cut out to locate the timing ignitor cup may be slightly off due to manufacturing tolerances and this is why you will need to re-time your bike....also, if buying a used bike its a good idea to check in case the PO had pulled it apart and put it back together wrong.
Old Aug 14, 2012 | 02:30 AM
blair's Avatar
blair
it need to be right or problems wont be far behind
Old Aug 14, 2012 | 07:12 AM
Jim Kraft's Avatar
Jim Kraft
When I did my cam brg., I marked the sensor position. After everything was back together, I checked the timing while running, and it was right on. I would still check it whenever I had it apart, just to make sure it was right. It is a little messy without the timing plug, but I get the job done. I do not however check the timing at regular intervals, as it really should not change after being set. I do check to make sure the VOES is working everyonce in a while.
Old Aug 14, 2012 | 07:48 AM
1997bagger's Avatar
1997bagger
Lt.
Simple answer is efficiency and safety, I tried my best to explain what is going on at the end of the attached thread, educated people will not come off their secrets of timing adjustments, they make a living with timing experiance.
https://www.hdforums.com/forum/evo-c...r-rockers.html
Old Aug 14, 2012 | 11:56 AM
LowriderHarold's Avatar
LowriderHarold
Default Very good Info
Glad I found this site. A lot of good info. Been riding old iron for a lot of years & new to the world of Evo's. By the way, got Donnie's book on Evo's. He even signed it. Also have the other book's that were mentioned. Very informative. Keep it up. I will have question's in the near future. Ride safe,
Harold
vanmor
Shovelhead
Oct 20, 2024 09:25 AM
fxstcmike
Exhaust System Topics
Aug 10, 2013 10:54 AM
HoggyMtnBreakdown
Aug 20, 2011 08:59 AM
htrod9592
Jan 13, 2010 05:22 PM
pauletich
21
Sep 6, 2007 05:17 PM
