Flushing Brake lines
Old Aug 16, 2012 | 10:28 PM
LowriderHarold's Avatar
LowriderHarold
Default Flushing Brake lines
Winter's round the corner & would like to flush out calipers & lines. I know moisture use to build up in the slave cylinder of my shovel, & make a mess. Been two yrs since I replaced brake lines & caliper's on my Lowrider, & would really like to flush them out & put fresh fluid's in. Any one have recomendation's of cleaner I can safely flush through my system? I bought a Mityvac when I installed brake's, so getting the fluid's through won't be a problem. Ride safe,
Harold
Old Aug 16, 2012 | 10:57 PM
Spanners39's Avatar
Spanners39
If its dot 5 it doesn't absorb moisture but its a good idea to change your fluid every coupla years.....just flush it through by bleeding it throughly until what comes out is nice and clean.
I use a syringe to suck any crud out of the master cylinder resevoir before changing the fluid this way.
Old Aug 16, 2012 | 11:17 PM
LowriderHarold
Default fluids
It is dot 5. Had dot 3 in the shovel, & every couple of yrs , it got real nasty. Disc brakes on 2 wheel's are new to me & lovin it! figured puttin anything through the system, besides brake fluid, might be a bad idea. Had to ask.
Thank's
Ride safe,
Harold
Old Aug 17, 2012 | 03:13 AM
Spanners39's Avatar
Spanners39
If switching from dot 5 to 4 or vice versa you can flush with meths but let it dry out before refilling.
Old Aug 17, 2012 | 11:44 AM
Uncle G.'s Avatar
Uncle G.
No need to flush it unless you believe the fluid has some real contamination in it. I use an old turkey baster to suck most of the old fluid out of the reservoir. I fill the reservoir with new fluid then simply bleed the brakes until I see new fluid coming out the bleeder screw. Check the reservoir level occasionally to make sure you don't run it dry while you're bleeding the calipers.
I do this to both brakes once a year, which I'm sure is overkill.
Jeff Dodson
EVO
22
Feb 26, 2019 11:31 AM
bikeguy1961
Sep 23, 2011 07:48 AM
miandsh2000
Wheels/Tires
Aug 4, 2010 01:52 PM
Ace07FXDL
Apr 11, 2010 08:44 PM
jonnyrotton
Dec 22, 2007 10:42 AM
