Charging Issue
Old Aug 18, 2012 | 11:37 AM
Classic Eagle's Avatar
Classic Eagle
Default Charging Issue
'96 EGC Evo. Just started doing this. Bike starts just fine. Runs just fine. No charging issues with the battery and it dosent go dead. But here is whats going on. When good and warmed up.. Volt meter shows up around 13 volts while riding but when I get to a red light or stop sign it seems to drop to just below 12 volts at idle. At night I noticed the head light dims slightly. Question...Stator or Regulator or both?
Old Aug 18, 2012 | 01:16 PM
miacycles's Avatar
miacycles
Could be either, could also be a weak battery, or battery connection. Could also be idling too slow too or have parasitic losses. Hope this helps.
John
Old Aug 18, 2012 | 01:22 PM
Stiggy's Avatar
Stiggy
My volt meter does the same, but my headlights stay bright. That's normal for my 3 Phase aftermarket system, ( CompuFire.)
I'd check your battery.
Old Aug 18, 2012 | 01:29 PM
Gunslingertom's Avatar
Gunslingertom
Check your voltage at your battery with a good meter before you make assumptions. Don't forget to clean and tighten every ground.
Old Aug 18, 2012 | 01:37 PM
jeffreydsilver's Avatar
jeffreydsilver
Default Battery!
Battery! Battery! Battery!
Did I mention to check the battery? After checking to make sure all connections are good and clean, change the battery!
Old Aug 18, 2012 | 01:47 PM
soft 02's Avatar
soft 02
Testing the bat with a volt meter and checking it with a load tester are two different things. A week battery could start the bike fine but after its warmed up and riddin it could get week. I do think going to a 3 phase system is the best option if everything else checks out.
Old Aug 19, 2012 | 09:17 AM
Classic Eagle
The battery is about 7 years old now. It could be possible. I'm gonna check it today before we go out. I never have a problem with start ups cold or hot. Battery has never been dead or discharged. Stays on a tender during down times and winter.
Old Aug 19, 2012 | 09:27 AM
Mike T's Avatar
Mike T
It's probably fine but you're getting close to the lifespan of a battery, even using a Battery Tender.
Old Aug 19, 2012 | 10:41 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You got 7 years out of one battery????
Damn good job. It was my understanding that bike batterys were only good for 3 years.
Old Aug 19, 2012 | 01:18 PM
miacycles's Avatar
miacycles
Seven years in battery life is like 210 years in people life!!!
John
