Compliance fitting
Old Aug 29, 2012 | 04:34 PM
FlyBD5's Avatar
FlyBD5
Default Compliance fitting
Hi folks,
I found some threads that talk about this but not enough information to understand what it all means.
Just got my 89 FLHS back from the shop and one of the things they did was replace something called "compliance fittings". I can't find that in the shop manual and I have no clue what they do, other than they seem to have something to do with the intake manifold?
The truth is, my bike runs a LOT better now. I also saw some comments that it's best to throw those away and replace them with something else. Why, and what is the best way to go for replacements?
I'm all ears.
Old Aug 29, 2012 | 04:38 PM
FlyBD5's Avatar
FlyBD5
No sooner posted, I found this. Is this an accurate description of the issue and the solution? Is S&S a good option for this?
The S&S manifold conversion kits for Harley-Davidson® Evolution® big twin engines are designed to replace the original rubber "compliance fitting" style manifold and seals used on 1984-'89 big twins, with a rigid mount aluminum manifold. The stock style rubber compliance fittings, used in this range of model years, are subject to degradation due to heat, age, and exposure to petroleum products. Intake leaks are a common problem with the compliance fittings due to cracks in the rubber.
The most common symptom of an intake leak is an erratic idle, but intake leaks can cause poor overall performance, and in extreme cases, can cause serious engine damage due to a lean mixture in one or both cylinders. By upgrading to the S&S rigid mount manifold, these cracking and leaking problems are eliminated. In addition, the improved flow of the S&S manifold can help improve performance.
Old Aug 29, 2012 | 04:59 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Are you saying that a compliance fitting replaces the rubber intake gaskets?
Old Aug 29, 2012 | 06:04 PM
brainless fxst's Avatar
brainless fxst
The compliance fitting is the rubber part of the intake there pretty big they bolt to the heads and the manifold goes into them they crack and tear. sometimes you can't even see the crack but it will suck air under load so they can go undetected. I think they were on early evos till 90 or so
Old Aug 30, 2012 | 09:39 AM
rivercityslim's Avatar
rivercityslim
The first thing I did to my '89 when I got it several years ago was to swap out the old butterfly carb and manifold with compliance fittings for a late model CV carb and manifold. Instant noticeable improvement. I believe '89 was the last year for that carb/manifold type, with good reason.
Old Aug 30, 2012 | 10:09 AM
miacycles's Avatar
miacycles
A few manufacturers tried a solid manifold with bad results. The cylinders grow and a solid manifold cannot stretch to match.
John
Old Aug 30, 2012 | 08:48 PM
notlost_nc's Avatar
notlost_nc
The compliance fitting was replaced by an aluminum intake that was rubber mounted to the heads. This allowed a bit of give and take as the head heated up and cooled off. I replaced mine and never had another leak. Are those fittings even available anymore? Should be obsolete....that's one part we can do without.
Old Aug 30, 2012 | 09:17 PM
Scratt's Avatar
Scratt
The older EVO's used rubber hose's (radiator hose) from the intake manifold to the heads. HD then upgraded to solid "Y" with rubber O rings between the intake and the heads. The "compliance" gasket is the rubber gasket (flat O ring with a groove) that get's placed onto the intake manifold (behind the carb) and then the carb is pushed into that.
The solid mount in my opinion works better then the hoses, my Brother has an 86 Wide Glide and he went with an S&S carb (Super E, intake included ). He loves it.
Old Aug 31, 2012 | 12:52 AM
FlyBD5's Avatar
FlyBD5
Well, the bike runs a heck of a lot smoother with the new compliance fittings. Before it would miss once in a while at cruising speed, and it just wasn't smooth at lower RPM's. It sounds and feels a lot better now.
Old Aug 31, 2012 | 04:38 AM
Uncle G.'s Avatar
Uncle G.
As I remember, there used to be a "secret" recall on the old style manifold back in the day. "Secret", in that Harley would cover the cost of replacement if the customer complained, otherwise not. I found out about it by overhearing someone discussing it at the parts counter at the dealership. That's how I got my Sportster upgraded.
Of course, that was long ago. Today, Harley barely acknowledges that they ever built the Evo, let alone warrants anything.
