My '92 EVO CV carb spits gas out the ventura under a load, ie. 70mph in 5th gear. when running easy it doesn't happen. I have tried 3 dif. carbs and they all do the same thing. I have set the float by the book and reduced the float level down a little a couple of times, no change. Any Ideas?
You could have an small air leak aound manifold if this is happening with other carbs. Get some starte fluid, start the bike and sray starter fluid around intake, if you hear a change in ideal speed, you have leak. Keep it away from the air intake when doing the test.
Did air leak test and had leak, replaced o-rings and it got better ( less response to start fluid), thought that fluid was migrating to air intake. I now have new filter (K&N) and air box. I'll try it again today. after I finish my coffee. Thanks!
As I said before about the exhaust was shortened about 4" I will check into a set of drag pipes today. Thanks for the help, I think this my be my problem,(I HOPE) any way Thanks.
Well I guess drag pipes aren't what I should think about, my problem is cash I'm trying to survive on SS so I'm limited on funds, I was looking at exhaust systems and every thing is pretty pricie, guess I'll do a little looking around on craigslist and such. I think you might be right, I've tried every thing else that I could think of. THANKS again, we'll get it figured out. :-)>
What if I eliminated the cross over pipe between the front and rear pipes?
If you did that, you would be better off with longer pipes so the 2 cylinders can get some balance.
Where is your compression? if it's too low, you will get fuel coming back out the venturi. If your main jet is too big, you could also get this effect.
Hatch.
