Scmin Eagle heads?
Old Sep 15, 2012 | 03:01 PM
Scudder's Avatar
Scudder
Default Screamin Eagle heads?
I had my '93 Softail motor rebuilt this past winter and all this season I have been dealing with a lean/intake leak problem. I have finally narrowed it down to the manifold length {the distance between the heads}. My Indy had a set of used Screamin Eagle heads that he did a valve job on and we used them on the motor. Is any body here using the SE heads and did you have to use a different manifold? I have tried 2 different carb setups and 2 different manifolds on the current Ultima R2 carb. All with the same shitty results. Any body?"
Old Sep 15, 2012 | 04:39 PM
Shredding rubber's Avatar
Shredding rubber
The older castings had a manufacturing issue and were removed off of basically new bikes,which created a massive surplus and they could be found pretty cheap.
Because of their size they are too big for anything smaller than a well built,heavy breathing 110" from what I have read.
I almost bought a pair for my 106" until my builder explained the whole thing to me. I opted for a worked over pair off an 88"
Old Sep 15, 2012 | 05:03 PM
miacycles's Avatar
miacycles
I always tried to stay away from the S/E stuff, however they did have a S/E manifold for both the stock CV and the larger S/E CV. I don't know if it is a companion piece for the heads or not. I don't know why they would be different than stock unless the heads are taller.
John
Old Sep 15, 2012 | 06:04 PM
Schex's Avatar
Schex
These might work for you, they have a lip over the edge of the manifold.
http://www.jpcycles.com/product/401-372
Old Sep 15, 2012 | 08:46 PM
Scudder's Avatar
Scudder
I don't know how old these heads are, but when I can get a decent seal, It runs great. I just can't get the seals to stay in place.
Old Sep 16, 2012 | 05:43 PM
miacycles's Avatar
miacycles
Is your air cleaner bolted to the heads or is the carb supported some other way???
John
hbever
Engine Mechanical Topics
Dec 5, 2015 08:36 PM
DanDman
Oct 2, 2012 12:49 PM
2005 Roadking
Oct 9, 2010 11:18 AM
z edge
Exhaust System Topics
Oct 22, 2009 12:25 PM
huey408
Aug 6, 2009 04:41 PM
