evo miss
Old Nov 12, 2012 | 12:51 PM
Dr.ultra2010's Avatar
Dr.ultra2010
Default evo miss
engine miss on 96wdg 80ci...replaced plugs,wires,changed out gas,checked compression,checked push rods,checked coil..???? what else can i check,still missing???????????
Old Nov 12, 2012 | 01:29 PM
1984_FXRT's Avatar
1984_FXRT
Describe the miss - is it a rough idle, misfiring gently under load, backfiring/coughing/dying when you give it ANY throttle, intermittent breakup at steady throttle?
Old Nov 12, 2012 | 02:04 PM
Dr.ultra2010
1st start bad miss only front cyl hitting and hot,, rear cyl cold.when riding rear cyl gets hot pops thru pipe,some backfire also,when you stop dies
Old Nov 12, 2012 | 02:17 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Fuel injection or carburetor?
Old Nov 12, 2012 | 02:20 PM
Dr.ultra2010
carb its clean,clean filter.............
Old Nov 12, 2012 | 02:22 PM
Gigawitz's Avatar
Gigawitz
What kind of ignition? stock, aftermarket? it's likely the problem..
Old Nov 12, 2012 | 02:28 PM
Dr.ultra2010
everything is stock,bike only has 19k,fluids get changed more than i ride this one.....where is the ign located???? not much of a mech..
Old Nov 12, 2012 | 02:38 PM
1984_FXRT's Avatar
1984_FXRT
If it's a stock (dual-fire) ignition, switch that spark plug leads, and see if the problem follows the plug wires.
If you don't know - then tell us how many skinny wires are going to your ignition coil. If you've got 2 skinny wires, and 2 plug wires, it's a dual-fire ignition. If you've got 3 skinny wires, it's a single fire and my suggestion to swap plug wires on the coil posts won't work.
Old Nov 12, 2012 | 03:08 PM
jimsflh's Avatar
jimsflh
I had that problem, ended up being a loose positive battery cable
Old Nov 12, 2012 | 03:40 PM
Bengo's Avatar
Bengo
I am going with ignition too, out here in AZ in summer heat my bike still hates me. Anyone have and idea of running with ignition cover off is a good or bad idea?
