evo miss
Old Nov 15, 2012 | 08:48 AM
  #31
wammerjammer's Avatar
wammerjammer
offroader >yours sounds to me as the timing is retarded and firing before full compression that will cause all your symtons running hot missing caughing ets do a static time on it hope this helps
Old Nov 19, 2012 | 11:15 PM
  #32
bucker18's Avatar
bucker18
try spraying carb cleaner on the manifold while running to see if it may have a leak that will cause a bad miss
Old Nov 20, 2012 | 01:55 AM
  #33
2AMGuy's Avatar
2AMGuy
Community Influencer
Always go with the cheap stuff first.
Check and clean both battery cables at the battery and also the ground cable to the frame.
Be sure the battery has a good charge.
The carb on my '98 Evo gave me real headache this past spring.
Remove, disassemble and thoroughly clean the carb and blow it out several times with compressed air and be sure that the float level is adjusted correctly.
With the carb off replacing the intake seals isn't much of a job and as old as they are they should be replaced and they're not very expensive.
Make sure you have fresh fuel.
I've had two bad ECM's in the past and each one acted differently but neither seemed to have only one cylinder firing but anything is possible.
Old Jan 19, 2013 | 02:54 PM
  #34
Houses's Avatar
Houses
Originally Posted by Dr.ultra2010
thanks for all the help i will ckeck all that was suggested...........
Curious Doc,
Ever figure this one out? Got something similar going here...
r/Houses
Old Jan 21, 2013 | 05:22 AM
  #35
wammerjammer
mine turned out to be a bad intake mahifold gasket sucking air into rear cylinder .i bought some felpro gasket material and made my own and it runs better than it ever has
Old Jan 21, 2013 | 06:26 AM
  #36
Gez's Avatar
Gez
6th Gear
does if have a crank sensor if it does look at it its probably melted the what ever is packed in i have had this in south australia above 35 degres C it started back fireing spoke to the experts and wasted alot of money took cover of the crankcase sensor saw the damage and repaired it with quick drie araldite two pack glue works well 37-38 degrease C a few ride and i quit the ride istead of the electra glide i hope you solve it good luck i also made a transparant vented cover for the hot season so i can look at it without taking the cover of
Old Jan 4, 2014 | 11:07 AM
  #37
allegedly's Avatar
allegedly
Stage IV
Hi guys, Rob here, newbie to the forum. Excellent site and excellent answers to the queries. I've a similar problem that seems to clear after running for a while. So, thanks for the input guys, lots to mull over there and learnt a lot too.
Riding a '95 Fatboy when I'm home but out in Middle East for a lot of the year so she doesn't get used as much as should.
Regards R
Old Jan 4, 2014 | 01:48 PM
  #38
factorybuilt's Avatar
factorybuilt
There is a ton of info on this forum. Thank you for your service to our country!
NDanecker
Milwaukee Eight (M8)
Jul 25, 2019 03:54 PM
Rowjimmyrow
EVO
Jun 26, 2018 07:18 AM
muaymendez1
Carburetor Related
Apr 9, 2018 12:06 PM
pontiac69
Apr 26, 2011 05:08 PM
ssls6
May 27, 2009 12:26 PM
