cleaning heads
Old Nov 21, 2012 | 12:49 PM
jsbridgew's Avatar
jsbridgew
Default cleaning heads
hey folks,
got my heads off and looking to clean the carbon out of everything
was getting oil past my rings so you can imagine the buildup
any ideas? ....parts cleaner and soak them?..... will the viton stem seals get damaged?
Old Nov 21, 2012 | 01:57 PM
miacycles's Avatar
miacycles
Spray throttle plate cleaner will work well. You could send them out and get them "cooked" but if they are black the color may either come off or get discolored.
John
Old Nov 21, 2012 | 02:24 PM
jsbridgew's Avatar
jsbridgew
thanks again, john!... much appreciated
i'll head out to autozone and pick up a few cans and give both heads a good douching
Old Nov 21, 2012 | 04:01 PM
Jasper86's Avatar
Jasper86
I had great luck with my small ultrasonic cleaner (I got it from Harbor Freight to use on gun parts) and warm water / dawn dish soap. small wire brush to work on the tough stuff (after its soaked)
(in all seriousness, a lot of gun cleaners work REALLY well to soften up carbon)
Old Nov 21, 2012 | 05:17 PM
Spanners39's Avatar
Spanners39
While the heads are off you might as well replace the valve seals and grind the valves anyway.
Old Nov 21, 2012 | 05:28 PM
Tee&Vee's Avatar
Tee&Vee
Could this happen if the rings were aligned? They're supposed to be set at 0, 120 and 240 (degrees) right?
Old Nov 21, 2012 | 05:32 PM
Tom84FXST's Avatar
Tom84FXST
If the build up is carbon...simply soak them in plain water over night...next day you can scrape it off with a wooden stick...like a popsicle stick.
Old Nov 21, 2012 | 06:10 PM
jsbridgew's Avatar
jsbridgew
really, Tom? ...i'll give it a shot, for sure
i just ordered a valve spring compressor, so i'm gonna pull each one apart and clean in there good
Tee&Vee.... long story
Spanner.... heads have only 2k on them after complete rebuild from Don at Deweys
dlynch851
General Topics/Tech Tips
May 20, 2015 04:31 AM
HarleyReece
Detailing
Apr 3, 2012 05:31 PM
07 dyna man
Apr 30, 2011 04:11 PM
outback2970
Engine Mechanical Topics
Feb 10, 2009 06:13 PM
PosseRider
Nov 15, 2007 01:30 PM
