head porting
Old Oct 8, 2010 | 08:12 PM
07 dyna man's Avatar
07 dyna man
Default head porting
back in the 80s i used to do some head porting on the side for people,, on chevy and ford heads,, so recently i had my harley heads professionally ported after looking at them , i won a set of 07 heads on ebay and went to work on them,anyone handy with a dremmel or a die grinder can also do this, you dont have to make the ports larger that would hurt your low end,as bean said just look down the port and be the air in these pics they are still in the rough stage, rite now i am sand blasting the combustion chambers so i can polish them, and then use 80 grit sanding rolls on the intake ports and make the exhaust ports as smooth as i can to prevent carbon build up,, take note of the guide bosses just narrowed them the same diameter as the guides
Attached Thumbnails head porting-abc.jpg   head porting-bcd.jpg   head porting-dc.jpg   head porting-dd.jpg   head porting-de.jpg
Old Oct 8, 2010 | 08:32 PM
dope_man_21's Avatar
dope_man_21
I have polished a few small block Chevy heads for our race car, and as you said anyone (that's willing to take the time) can do it, I am just not ready to try on the heads for my bike, perhaps if I had another set it would be game on. Also you can cc the combustion chambers yourself, many youtube videos out there on it, the most popular way is to sink the valve a little deeper, but you can also remove a little meat from the combustion chamber to make the two (or 4,6,8, what ever) match.
Old Oct 8, 2010 | 08:39 PM
07 dyna man
so far i spent about 2 hours on both heads, ive also made a plexi glass plate to put over the combustion chamber and i have a beaker in ccs to check both chambers
Old Oct 9, 2010 | 01:12 AM
dope_man_21
Sounds like you know exactly what you are doing, good luck.
Old Oct 9, 2010 | 06:25 AM
dog155's Avatar
dog155
Been doing my own stuff for years.It's all about port matching and bowl work,also the 85% rule.The port just below the seat should be 85% the diameter of the valve.Polish the combustion chamber breaking all sharp edges,helps eliminate spark knock.Most important is not to take too much material.
Old Apr 30, 2011 | 04:11 PM
07 dyna man
my brother dynoed his bike today with the heads i ported for him 05 fat boy 95" tw37s straight pipes,,,, 89 hp 99 tq.,,, not bad,,, sheet coming tonight
max738
Engine Mechanical Topics
11
Jun 23, 2022 03:07 PM
txphatboy
21
Mar 21, 2019 09:21 PM
Big J1
Feb 20, 2017 12:55 PM
FLS103
16
Jan 7, 2015 04:57 AM
HarleyForeverFLHX
Jan 18, 2008 05:48 PM
