86 fxr
Old Dec 1, 2012 | 09:17 PM
wammerjammer's Avatar
wammerjammer
Default 86 fxr
got a question for you all > i put in a Daytona Twinn Tech ignition put piston on front TDC at the stright up line went to toher side and turned ignition till red LED went off . do these ignitions automatically adjust for advance or should i have brought crank to the 35 degree dot then turned till LED went off > bike runs good just worried about pre detonation thanks for any replies
Old Dec 1, 2012 | 09:20 PM
Spanners39's Avatar
Spanners39
They have electronic advance curves but you should always strobe the timing once fitted so you know its right. The cam moves at half crank speed so any error at the module will be 2x at the crank.
Old Dec 1, 2012 | 09:38 PM
wammerjammer
yeah i better check it Spanners 39 to be safe i wasnt sure if they adjust automatically prolly do but best to check anyways
thanks
Old Dec 1, 2012 | 09:40 PM
wammerjammer
just curious as to what would have happened if i set the dot in the hole then made red LED go out and not at the TDC line ??
Mason32
EVO
13
Dec 19, 2017 05:31 AM
Jonk777
General Topics/Tech Tips
Jun 29, 2016 04:21 AM
nolabel
Sep 4, 2013 01:13 PM
inkslinger73
EVO
Jul 9, 2013 08:26 PM
cncprogrammer
Oct 25, 2012 05:05 AM
