Ebay Andrews EV27?
Old Jan 3, 2013 | 08:52 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Pinetop
checkout powersports in Austin,
tx. they are the cheapest I have found
There are a couple of Powersports in Austin TX. If you are talking about the one on Stassney Ln. they do great work.
The cheapest I have found is Antler Creek Cycle Leathers.
http://www.antler-creek.com/
If he can find it in a catalog he sells it for 10-20% less than they ask for in the catalog.
Geoff is good people but the only thing he keeps stock on hand is leathers and helmets. He can order in anything you want though.
512-441-2427
Old Jan 3, 2013 | 10:59 PM
Pinetop's Avatar
Pinetop
Default Evo green and black dot gear owners
While putting in the recent purchases of Andrews adjustable rods, Johnson lifters and Andrews ev27 I read something I had not read or been told. For those Evo owners whose engines contain green or black dot gears the common ev27 i.e. 291127 is not what your or my bike needs. It appears that our gears or oversized and therefore require different part number. I sure hope the seller agrees to an exchange as I recommended them in this forum. Disappointed that I could not get it done tonight. Hopefully all goes well tomorrow and she rides like she is on fire. Also installed new stock ignition as the wax on the old one had finally caused the bike to run badly. Caution, if you see melted wax change it.!!!!!!!!!!!!!!!! Thankfully I was near home and therefore drove home with no problems.
Pinetop
Old Jan 4, 2013 | 06:32 AM
Edster 69's Avatar
Edster 69
Pinetop your losing me on this one?? The EV27 is made SPECIFICALLY for ALL Evo motors. Please elaborate on where you got this info from?? Something doesn't sound right at all.
Old Jan 4, 2013 | 11:51 AM
Pinetop's Avatar
Pinetop
I will scan and post the information sheet which came with the cam. Yes the ev27 is made for the Evo but there are different model numbers to take care of the bikes made after 1990 which have either green or black dots on them indicating the oversize from the factory. I was under the same impression you are but after comparing the gears, measuring with digital caliper and placing the new cam into the pinion gear grooves it is obvious that it does not fit my bike as presently constituted.
If anyone is contemplating the purchase of an Andrews ev27 you need to check your cam and pinion to make sure of the fit. I will post by early evening.
Pinetop
Old Jan 4, 2013 | 08:44 PM
Broncobilly72's Avatar
Broncobilly72
Pinetop,
Please post that scan of the EV27 info sheet when you have a chance. I just ordered the EV27 for my 97 RK a few days ago
Old Jan 4, 2013 | 11:15 PM
texashillcountry
Dirt don't hurt
I found out that the best thing you can do is take the gear off your stock cam and have it pressed on the cam you are putting in.
Old Jan 4, 2013 | 11:25 PM
Pinetop's Avatar
Pinetop
Default use same gear
texas hill that is correct. when I discussed the need for a different pinion gear a mechanic at the dealership suggested that for $24.00 I could just have my old gear pressed unto the new cam. 20 minutes and I was out. I will post it either later tonight or in the am.
Pinetop
Do you know if you have green or black dot gears? otherwise the problem does not exist.
Old Jan 4, 2013 | 11:32 PM
texashillcountry
Dirt don't hurt
Actually at the time I did mine I didn't know about this trick when I did mine.
Neither my stock cam nor the EV-27 had any color dot on them.
I have learned a bunch about Harley's since I did mine and if I had to do it over I would do it differently.
Basically all I did was pull the stock cam and replace it with the EV-27. There was an annoying whine for a few thousand miles but it went away.
Old Jan 4, 2013 | 11:54 PM
Broncobilly72
I found a link which has the Andrews install info sheet. You need to scroll down, then click on a PDF link. Here's the url http://www.hognutz.com/engine-cams/926/
Texas,
Thanks for mentioning pressing on the original gear. I never thought of that! I have a 12 ton press in my garage
Old Jan 5, 2013 | 12:00 AM
PanHeadRich's Avatar
PanHeadRich
Originally Posted by Broncobilly72
PanHeadRich,
We'll I finally got around to ordering my EV27 cam. Based on your and other's input. I can't wait to see the changes in performance - with the old Road King. It will be nice having more power to pass semi's with now Next up is ordering up the Andrews adjustable lifters.
Good for you bud. I got my push rods from this seller for $109 shipped. You might want to see how that compares to others pricing. I didn't really shop it around much, so I don't know if it was a good price or not. But they did ship them right out.
http://www.ebay.com/itm/ANDREWS-ADJU...item53f020ad55
Brick0044
Sep 8, 2012 11:24 AM
mrfikser
Nov 30, 2011 08:08 PM
badwiser
Feb 23, 2010 11:41 AM
JCK
Oct 16, 2009 09:44 AM
steveultra08
Mar 16, 2009 09:36 PM
