getting ready to "push the button"
Old Jan 16, 2013 | 06:32 PM
traildog's Avatar
traildog
Default getting ready to "push the button"
Any last suggestions, or should I filler up, pull the enrichener, blip the throttle, and PUSH THE BUTTON?
Old Jan 16, 2013 | 06:35 PM
Jasper86's Avatar
Jasper86
I skip the choke. 3 1/2 turns on the idle adjuster for the mikuni, 2 twists of the throttle, and she fires right up
Old Jan 16, 2013 | 06:40 PM
bluharley's Avatar
bluharley
I was always told to turn it over without fuel or fire first, make sure nothing is banging into anything else.
Old Jan 16, 2013 | 06:50 PM
traildog's Avatar
traildog
WELL,the friken tank level sensor just fell into the tank.....might be a while now.....
Old Jan 16, 2013 | 06:54 PM
bluharley's Avatar
bluharley
WELL, that sucks! What I did before I started it up after a tear down is pull the plugs out and leave the fuel off, should just roll over smooth as silk. If something isn't right, you'll know, rather than let the engine tear itself up. Bummer about the sensor. You'll have to tell us how that happened?
Old Jan 16, 2013 | 07:42 PM
traildog's Avatar
traildog
made a video, but she wouldn't start. checking stuff now.
Old Jan 16, 2013 | 08:03 PM
Jim Kraft's Avatar
Jim Kraft
When I changed out the cam bearing in mine, I turned it over with the back wheel and the plugs out to check out everthing. I also poured oil all over everthing in the cam chest when I put it together. When I hit the starter she fired right up and made me smile. I had soaked the lifters in a can of oil before putting them back and had no noise from the valve train at all. I have put about 12,000 miles on it since without problems.
Old Jan 16, 2013 | 08:14 PM
traildog's Avatar
traildog
uploading the video now. didn't hear anything strange, but I don't think shes getting fuel for some reason
Old Jan 16, 2013 | 09:20 PM
misfitJason's Avatar
misfitJason
no video yet?
Old Jan 16, 2013 | 09:36 PM
traildog's Avatar
traildog
Dam thing is takin FOREVER! Probably be tomorrow now.
