getting ready to "push the button"
Old Jan 17, 2013 | 11:39 AM
Schex's Avatar
Schex
Sure that it has compression? sounds like it's spinning with the plugs out.
Pull a plug right quick, put your finger on the hole, see what ya got.
Old Jan 17, 2013 | 12:15 PM
traildog's Avatar
traildog
I'll be checking lots later. Thanks for the suggestions.
Old Jan 17, 2013 | 12:56 PM
Jim Kraft's Avatar
Jim Kraft
When you adjusted the valves are you sure you did it on the firing stroke? It is possible to adjust them on the intake exhaust stroke at tdc. I always remove the timing inspection plug so I can see the timing mark on the crankshaft to make sure that when the piston is at tdc it is on the firing stroke. Just a thought.
Old Jan 17, 2013 | 01:10 PM
traildog's Avatar
traildog
I adjusted them per Velva Touch's instructions. I turned the rear wheel until the lifters were both on the bottom. Then adjusted the fronts and repeated for the rear.
Old Jan 17, 2013 | 02:10 PM
Jim Kraft's Avatar
Jim Kraft
That should be good.
Old Jan 17, 2013 | 02:21 PM
traildog's Avatar
traildog
I hope so. I don't hear any "bad" noises when she's turning over.
Old Jan 17, 2013 | 03:55 PM
traildog's Avatar
traildog
Spark, Check
Fuel, Check
Compression, Check
Now what?
Old Jan 17, 2013 | 04:14 PM
bluharley's Avatar
bluharley
All I know is, you can't sleep or work til it's running. The anticipation is killing me! I'm puzzled. The single fire I don't understand, other than that, seems like it should run.
Old Jan 17, 2013 | 04:31 PM
NC_Grover's Avatar
NC_Grover
I would try squirting some ether in the intake as mentioned before if you haven't tried that yet.
Old Jan 17, 2013 | 04:42 PM
traildog's Avatar
traildog
Dam, no ether. What now. She seems like she wants to go, but wont.
