getting ready to "push the button"
Old Jan 17, 2013 | 05:44 PM
  #41
MMMichael's Avatar
MMMichael
What was done to the motor? I just read this thread and it didn't pop out at me if it's in here..
Sounds to me like timing... It would make sense if you are getting spark, fuel, and it has compression, but it isn't getting them all at the right time. Get it? That's what used to happen to me on the cars I would restore.
Old Jan 17, 2013 | 05:52 PM
  #42
bluharley's Avatar
bluharley
I don't know the answer to this question, so..... I wonder what happens in a single fire if the plug wires are reversed? Like nothing? Or BANG?
Old Jan 17, 2013 | 06:00 PM
  #43
traildog's Avatar
traildog
She's done for tonight. Starter is just spinning now. Must have fried the clutch AGAIN.
Old Jan 17, 2013 | 06:01 PM
  #44
95 Ultra's Avatar
95 Ultra
Is the vacuum line attached to the petcock and carb??
Old Jan 17, 2013 | 06:03 PM
  #45
bluharley's Avatar
bluharley
You rode this thing before the operation, didn't you?
Old Jan 17, 2013 | 06:08 PM
  #46
traildog's Avatar
traildog
Yep
Yep, did 5K on her.
I must have SOMETHING screwed up.......
Old Jan 17, 2013 | 06:31 PM
  #47
traildog's Avatar
traildog
Took the top end apart to fix a leaky base gasket.
Old Jan 17, 2013 | 07:14 PM
  #48
bluharley's Avatar
bluharley
The starter spinning I doubt is your clutch. You could remove your clutch plates and it would still turn the engine over, it just wouldn't engage the tranny. That's a new concern. I can't think of anything you've done that could be doing this, except those plug wires. Your single fire ignition is something I don't completely understand, but it sure sounds like timing, since spark and fuel are both there. Timing would explain the little umph you get now and then. All this cranking, have you ever flooded it? Just thinking.....
Old Jan 17, 2013 | 07:25 PM
  #49
traildog's Avatar
traildog
I meant the STARTER clutch.
Yep, I've flooded it before. The gas smell was pretty strong. Not tonight.
Just thinking.....
Thanks, and keep the thoughts/suggestions coming.
I think I'm gonna take a look at the timing tomorrow.
Old Jan 17, 2013 | 07:30 PM
  #50
bluharley's Avatar
bluharley
I wonder where everyone is tonight.
