getting ready to "push the button"
Old Jan 20, 2013 | 08:38 AM
  #141
traildog's Avatar
traildog
Originally Posted by Schex3x
If fail, drop back 10 yards and punt.(call the man)
OK. YOU owe me a NEW laptop! I just fired DIET DEW all over the screen!
Thanks for the laugh!
just did a WOT compression test. Both cylinders showing 170 psi.
Wire trick next. Stay tuned. YOU may WIN a FREE Mickey D's MEAL!
Old Jan 20, 2013 | 08:54 AM
  #142
traildog's Avatar
traildog
Sure would be nice if I could reach the coil without removing the frickin tank.
Old Jan 20, 2013 | 09:34 AM
  #143
1997bagger's Avatar
1997bagger
Walk before running, check carb accellerator pump pattern as just mentioned to confirm getting gas. Pull a plug wire to confirm blue spark, not yellow, if you have spark and gas then it is timing. Redneck timing test is to have the plugs pulled hooked to the plug wires and bump the starter, when compression exits the spark plug hole, the plug for that cylinder should fire close to the same time (single fire), if not then a ignition timing problem is present or wires are on the coil backwards as mentioned if firing on wrong cylinder.
Have seen electronic ignitions "forget" themselves with low voltage was present (battery discharge) during work performed and not start. Needed the power source removed and reconnected to "reset" it. The engine sounds like it is firing a small blurb out the exhaust when it happens.
You have good compression so the Velva Touch's set at 1 1/2 turns are OK. That compression is going to be a runner when she fires, Bertha will probaly shed some weight when she starts moving as fast as I think she will.
Old Jan 20, 2013 | 09:39 AM
  #144
traildog's Avatar
traildog
How will I know if the carb pump if working?
when I twist the throttle, gas shoots out.
Old Jan 20, 2013 | 09:47 AM
  #145
traildog's Avatar
traildog
unless I turn the throttle, nothing happens in the carb when she's turning over.
Old Jan 20, 2013 | 09:54 AM
  #146
lownslow's Avatar
lownslow
Here it is.............!!! As mentioned above.
1) Good compression....check.
2) Squirting fuel from accelerator pump.......check.
3) Big Fat Blue, not yellow or weak, spark.....check??????
4) Spark occurring at the right time......ckeck?????
Old Jan 20, 2013 | 10:07 AM
  #147
Schex's Avatar
Schex
It's got fuel, you good there.
I used to clip one end on the hot on the starter and carefully touch the other clip to the coil, or you'll be arc welding under the fuel tank, fun fun.
Or,
You hold the wire on both ends and get someone to hit the button.
Now that I installed the power relay it'll fire even if it just barely turns over.
Like 1997 bagger says, it would act like it fired out of time and maybe just backfire every now and then.
I would supply better voltage to the coil, and it would fire if I just looked at the starter button.
May not be your problem, but need to be sure.
Good luck!
Old Jan 20, 2013 | 10:14 AM
  #148
1997bagger's Avatar
1997bagger
Carb is fine then, I believe you said it fired earlier with aid and after that but not on it's own later which is strange, check that spark color as I believe you have a coil or ignition module failure, just because something is new doesn't mean it works, I oversee mechanical/electronic repairs daily and new electronic parts work for a startup and won't work next startup that throws us off until we circle back to the recently installed new part and it failed.
Make sure you check that ground supply wire to the ignition module, it sends alternating grounds to the outer terminals of the coil that fires it, if the module doesn't have a good ground or clean 12 volts, it can act like a failing module also so this is where a VOM comes into diagnostics.
If it was EFI changed to a carb, the cam pickup rotor also needed replaced due to different signal notches
Old Jan 20, 2013 | 10:15 AM
  #149
traildog's Avatar
traildog
I wouldn't call it big and fat, but the spark is blue.
Old Jan 20, 2013 | 10:18 AM
  #150
1997bagger's Avatar
1997bagger
Ok Traildog, we need a check, check
