Shorter Softail rear fender struts
Old Jan 17, 2013 | 08:54 PM
prochopp's Avatar
prochopp
Default Shorter Softail rear fender struts
Throwing a custom dyna style fender on 1998 softail and the stock struts are too long anyone know if fatboy or heritage struts would work?
Thanks,
Old Jan 18, 2013 | 06:15 AM
magna's Avatar
magna
Don't know wether those struts would fit, also don't know wether you've taken your struts off but if they're anything like the ones on Twin Camm bikes what your looking at is only a cover, the strut that does the work is a lot shorter thing underneath.
Old Jan 18, 2013 | 04:35 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by prochopp
Throwing a custom dyna style fender on 1998 softail and the stock struts are too long anyone know if fatboy or heritage struts would work?,
All strut covers of that era are the same length...the only difference is if they have holes for turn signals, and where those holes are located. They used to make covers so you could cut them shorter and hide the cut ...haven't seen those in a while. Most aftermarket shorter struts are designed to cut off the factory strut for use with a wider tire. Alloy Art lights would cover a minor cut...but there is a limit how far you can go since the cover is tapered.
Old Jan 18, 2013 | 10:31 PM
prochopp's Avatar
prochopp
Thanks for the info, looks like you have first hand experience with the issue
Old Jan 20, 2013 | 11:27 PM
langwilliams's Avatar
langwilliams
there's a how to somewhere on shortening your struts. You cut the lower lip off, leave the top lip intact. Cut the strut cover just behind the second to last hole (but not the lip). then wrap the lip around an have it tigged an polished.
Old Jan 20, 2013 | 11:32 PM
langwilliams
i think this is it:
http://www.chopcult.com/forum/showthread.php?t=806
Old Mar 2, 2013 | 12:38 PM
Tom84FXST's Avatar
Tom84FXST
J&P musta found some in the backroom
http://www.jpcycles.com/product/711-...9-93e33113de40
stonewall308
May 29, 2024 03:12 PM
BillyBreakout
Mar 24, 2014 05:50 AM
brettnbama
Apr 4, 2012 07:54 AM
mnkanderson
May 2, 2011 08:27 PM
paisleysdaddy
Jan 23, 2011 11:44 PM
