starting issues
Old Feb 7, 2013 | 10:36 PM
greasemykey's Avatar
greasemykey
ill check hold on
Old Feb 7, 2013 | 10:38 PM
greasemykey
i have 9.9-10 volts before i push the switch and 12.5 when the switch is pushed
Old Feb 7, 2013 | 10:43 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Ok that is good.
Now unplug both ends of the green wire, check connections, and do a continuity check.
Old Feb 7, 2013 | 10:46 PM
greasemykey
which pin is the wire from the solenoid?
Old Feb 7, 2013 | 10:51 PM
texashillcountry
Dirt don't hurt
87 is the wire to the solenoid.
Just for fun also check that pin 86 has a good ground (continuity check).
greasemykey
i put the meter on 200 ohms and got 00.1
Old Feb 7, 2013 | 10:55 PM
greasemykey
i have nothing for the 86 to ground. cant find the end of the wire though
texashillcountry
Dirt don't hurt
Did your ground check out? (Pin 86)
Old Feb 7, 2013 | 10:56 PM
texashillcountry
Dirt don't hurt
Just go from the negative battery post to pin 86.
Old Feb 7, 2013 | 11:02 PM
greasemykey
i did and got nothing. i think i am going to unplug that pin and run it to the battery
