Jiffy Stand spring
Old Feb 18, 2013 | 05:51 PM
traildog's Avatar
traildog
Default Jiffy Stand spring
Mine seems to be getting quite weak.
Anyone else had to replace one?
Old Feb 18, 2013 | 06:05 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Not yet!!
Old Feb 18, 2013 | 06:06 PM
texashillcountry
Dirt don't hurt
You know TD as a fix it project you could have picked something more entertaining than a spring.
Just sayin'
Old Feb 18, 2013 | 06:12 PM
lionsm13's Avatar
lionsm13
I've always thought that would be one of the things that you should carry as a spare, that and a couple heavy duty electrical ties.
Old Feb 18, 2013 | 06:13 PM
Stiggy's Avatar
Stiggy
13 years and a zillion miles and not yet~tho' I now carry a skinny bungee cord to hold up the kickstand when/if it does break.
Old Feb 18, 2013 | 06:17 PM
traildog's Avatar
traildog
Hmmm, the stand drags sometimes when I lean into corners. I guess I better check to see if something's bent somewhere.
Old Feb 18, 2013 | 06:24 PM
texashillcountry
Dirt don't hurt
I got 5 bucks that says it is a worn out spring.
I have seen it an another bike.
Old Feb 18, 2013 | 08:37 PM
1997bagger's Avatar
1997bagger
We need a TD project, I think it is the rear swingarm bushings flexing in a corner allowing the stand to get closer to the ground, pull the swingarm and check for excessive play
Old Feb 18, 2013 | 08:47 PM
texashillcountry
Dirt don't hurt
That sounds like much more fun than a spring!!!!!!!!!!!!
Old Feb 19, 2013 | 06:12 AM
EVOrider's Avatar
EVOrider
I just replaced the spring on my 1998 Ultra....noticed the stand would not fully retract. The old spring on the bike looked fine, but compared to the new one....you could tell it was worn out. Also check out the black stand bumper on the frame to make sure it is in the right location.
Since it was replaced....the stand does not drag so often.
