Difference in oil pressure
Old Feb 19, 2013 | 05:33 PM
bluharley's Avatar
bluharley
Default Difference in oil pressure
Should there be a difference in oil pressure between the sender and the gauge I have on there?
Old Feb 19, 2013 | 05:57 PM
bluharley's Avatar
bluharley
Guess I'll answer my own question. It looks like the gauge is in the cam chest, and the sender is in the crank case. So I'm guessing the cam chest would have less pressure than the crank case, which is why I had 0 on the gauge at idle and 5 on the gauge. That's what I figure.
Old Feb 20, 2013 | 04:55 AM
grbrown's Avatar
grbrown
In addition I wouldn't regard either gauge as being very accurate. The only way of answering your question is if you could measure at both positions using the same gauge, to remove any discrepancy between the two.
My favourite indy calls oil gauges 'worry' gauges! He reckons they should be chucked in the bin, they cause him so much grief - from customers who fit them.
Old Feb 20, 2013 | 06:11 AM
Tom84FXST's Avatar
Tom84FXST
From everything I have read, the stock oil pump cuts off oil to the crank at idle...sending whats left to the valvetrain....hydraulic lifters really don't like 0 oil pressure...while the roller bearings on the crank really don't care. I have a gauge in the same position as yours,and it has read 0 oil pressure at idle for 15 years with no problems.
Old Feb 20, 2013 | 09:15 AM
bluharley's Avatar
bluharley
I agree. The needles wiggle, so something is happening. Good enough for me!
Old Feb 20, 2013 | 03:00 PM
machinehed's Avatar
machinehed
Default oil pres.
Noticed this on prev. posts. Harley has a very weird oil system and seeing 0 pres. at idle is apperantly normal .???
Old Feb 20, 2013 | 05:27 PM
grbrown's Avatar
grbrown
Wink
Our engines have mostly roller type bearings and don't need much pressure to lubricate them, unlike an auto engine with almost entirely plain bearings. Low pressure readings are indeed normal. Read my earlier post!
Old Feb 20, 2013 | 06:11 PM
miacycles's Avatar
miacycles
Two things; first the stock HD V-Twin oil pump doesn't put out a lot of pressure, 7-10 lbs per thousand RPM's is normal except at idle where it MAY run a little lower. Secondly oil guages are notoriously inaccurate. If you take a certified pressure gauge and check it against yours you will probably find a difference. If you really had zero oil pressure your engine would let you know right away. So in closing you can do two things, first look at the gauges when you are going down the road only. Secondly take off the guages and rely on you light. Make sure your idle is around 900-1,000 RPM's, many people have it set lower so it sounds cool, but it isn't cool for the engine. Hope this helps.
John
Old Feb 20, 2013 | 06:17 PM
bluharley's Avatar
bluharley
Thanks John. Now I have two gauges, but rely mostly on the light. But mostly, the sound would tell me something it wrong before I even notice the gauges or the light!
BiggestDawg
Sep 2, 2014 06:57 AM
jd8181
Jan 15, 2013 08:24 PM
hddon69
Apr 29, 2012 08:34 PM
sellout
Ironhead
Oct 19, 2009 12:35 AM
sportster orange
Jul 8, 2008 10:56 AM
