FXR build questions
Old Jul 30, 2014 | 08:14 PM
  #51
PanHeadRich's Avatar
PanHeadRich
Originally Posted by Stevos50nuts
Hey rich do the sportster buckets have that big connector in the back like ours. The fxr bucket has alot going on in there
Man, you aren't kidding that there's a lot going on in there. A couple things concern me. Even with the deeper Sportster Bucket I don't know if it would accommodate the LED and all the wiring & connectors. Another concern is how hot the heat sync on the LED gets. I guess you could plug it into your H4 connector, leave it on for a while then touch the back of the LED to check for heat. If it's too hot to keep a hand on, it's too hot to be resting against the wires.
I won't know for sure until a dig in deeper, but it looks like that wiring could be removed from the bucket and tucked under the shroud bracket. I'd shrink wrap the connectors to keep moisture out. I'm going to be installing a Rifle Roadster Quarter Fairing which will make tucking that wiring easier. But yeah, that turns a 1/2 hour bucket swap into a 3 hour job.
The Sportster bucket does not have that connector on the back either. My fork has the Air Ride suspension making it even more challenging. There's an air hose right behind the bucket that won't allow me to fit a Sportster bucket without relocating the hose. I'm sure I'll figure it out once I get taking things apart. But that won't be until it gets too cold to ride.
Old Jul 30, 2014 | 10:02 PM
  #52
Stevos50nuts's Avatar
Stevos50nuts
I have a plan. Ordered a $20 sporty bucket off ebay. Im gonna cut it up and add a part of it to my bucket. I will take some pics IF it works.
Old Jul 31, 2014 | 11:49 AM
  #53
PanHeadRich
That sounds like a great idea. I'll look forward to seeing the pics, thanks. I might be able to do the same. I'd need to extent the front portion outward to avoid moving the air line going into the fork. Any idea how much of an extension would be needed?
Old Aug 1, 2014 | 11:06 AM
  #54
Stevos50nuts
so I ordered the sporty bucket for 20 bucks and cut the outer 3/8th off. This way I can attach this to my existing bucking with extention piece without sacrificing my original bucket. I would just have to drill out 4 rivets to remove and back to square one. The strip I used was 1 1/4" in width. I think it came out great on my bike. Your not going to see it at all. I covered the seem with carbon fiber tape?? Heres some pics
Attached Thumbnails FXR build questions-1114.jpg   FXR build questions-1117.jpg
Old Aug 1, 2014 | 11:25 AM
  #55
Stevos50nuts
rivet ring to 1 1/4 strip. then rivet whole thing to bucket on bike. I will post a finish pic with my fairing on later
Attached Thumbnails FXR build questions-1120.jpg   FXR build questions-1122.jpg
Old Aug 1, 2014 | 11:28 AM
  #56
Stevos50nuts
put sticker over seem. If I wasn't putting fairing over it I would have to come up with a way to hide it neater
Old Aug 1, 2014 | 08:06 PM
  #57
PanHeadRich
Very well thought out Stevo! Thanks for posting the pics. Riveting was a great means of attaching as well. Any idea what the total extension measures?
Old Sep 21, 2014 | 07:47 AM
  #58
Stevos50nuts
Thought id post one last pic. Added S&S carb, luggage rack and chin spoiler
Old Sep 21, 2014 | 12:36 PM
  #59
SeaZund's Avatar
SeaZund
great project; looks like it's ready to rock&roll
Old Sep 21, 2014 | 07:02 PM
  #60
98hotrodfatboy's Avatar
98hotrodfatboy
nice job, looks good,,who makes the pipe..
