cam swap question
Old Mar 26, 2013 | 04:48 PM
Proud Marine Dad's Avatar
Proud Marine Dad
Default cam swap question
Do I need to worry about matching cam and pinion gear sets for a cam swap on a 96 roadking? According to the service manual there are 7 different cam and pinion gears marked with a specific color dot. Can I just install an ev27 and not worry about it? Yes I have a new torrington bearing.........I've read all those posts!!
Old Mar 26, 2013 | 05:23 PM
Jim Kraft's Avatar
Jim Kraft
You do need to make sure the cam gear is the right one for the pinion gear or else it will either whine, or clatter. You can take the gear off of your old stock cam and get it pressed on the new cam. That will work just fine. You will also need a shim for the new cam. I think most use .050" or so as they are that much shorter than the original.
Old Mar 27, 2013 | 08:46 AM
grbrown's Avatar
grbrown
Swap the gear wheel is simplest, so you carry on running the gear currently in your bike. You will need to install the cam to measure end float, then get the correct shim to set end float.
Old Mar 27, 2013 | 01:02 PM
JohnFlorida's Avatar
JohnFlorida
simplest is to buy a matching pinion gear, they're cheap
Old Mar 28, 2013 | 04:40 PM
Proud Marine Dad
Thanks for the info.
rainsong
EVO
23
May 3, 2017 01:50 PM
187
EVO
Dec 24, 2013 09:23 AM
terrapin88
EVO
Apr 22, 2013 05:52 PM
redrott
EVO
Jul 5, 2010 11:03 AM
Keener
Engine Mechanical Topics
Apr 22, 2009 09:07 PM
