Reading my plugs
Old Mar 31, 2013 | 09:21 PM
1997bagger's Avatar
1997bagger
Probaly everyone gets tired of hearing me harping about a AFR reader system but here is a 100+ hp front plug @ 14.0 idle 13.8-1 at cruise and 13.2-1 WOT, timing mark is in the center bend of the strap where it belongs, just posting it for referance. Sorry for being so repetative on my views of tuning.
Note: that is never seize on the threads that every plug manufacturer says not to use. Won't put them back in without it
Old Apr 1, 2013 | 12:00 AM
LowriderHarold's Avatar
LowriderHarold
Default Curious
Not to hijack thread, but have one question for ya , bagger about one of these AFR meters. Where did you mount the sensor for your readings? As I have Vance & Hines dual exhaust, I would think it would have to be mounted in such a place to monitor both exhaust outlets, & I dont see it with duals.
Ride safe,
Harold
Broncobilly72's Avatar
Broncobilly72
1997bagger,
Were do you have your oxygen sensor mounted on your pipes, for the WEGO?
Old Apr 1, 2013 | 12:02 AM
Broncobilly72
Harold,
You beat me by a millie second! I was thinking the same thing : )
Old Apr 1, 2013 | 12:03 AM
LowriderHarold
Originally Posted by Broncobilly72
1997bagger,
I wanted to know same info. Sorry for double post. He has my curiousity up with this meter.
Ride safe,
Harold
Old Apr 1, 2013 | 01:48 PM
bluharley's Avatar
bluharley
Default How are these?
My bike has been running crappy lately, cuts out now and then, slow to start. Do these plugs call for a richer environment? The rear (right) is brown only on one side, other side is white. Thanks.
Attached Thumbnails Reading my plugs-plugs-001.jpg   Reading my plugs-plugs002.jpg
Old Apr 1, 2013 | 08:14 PM
1997bagger's Avatar
1997bagger
1997bagger,
As close to the exhaust port of the head as possible with easy access to get a O2 sensor in and out. EFI needs needs 2 ports, carb needs one and the rear cylinder can run hotter because of air flow is slightly blocked, the plug shown in the pic is off the front cylinder
Old Apr 1, 2013 | 09:14 PM
1997bagger's Avatar
1997bagger
Use the plug picture chart that was provided earlier and some reading material in the attachment below helps in reading plugs
http://www.4secondsflat.com/Spark_plug_reading.html
Old Apr 1, 2013 | 10:24 PM
LowriderHarold
So, you drilled a hole , welded the nut for the sensor to screw in, your exhaust pipe, close to the exhaust port of your head, if I'm understanding you correctly. In my case , with a carb, I only need to do one.
Ride safe,
Harold
( And I assume when you get the air, fuel mixture where you wan't it, you take the sensor out & plug the hole)
Old Apr 2, 2013 | 06:03 PM
1997bagger's Avatar
1997bagger
Ride safe,
Harold
You are all over it!
