Well I got bored yesterday and when I went to replace the starter drive gear on the Yellow bagger, I thought "What the hell, let's put a belt drive on it". I had one in stock for another project so I did it. I took pictures as it went along and will post them hopefully tonight. It is an Ultima 2" belt drive for FLT, FLH, and FXR's. Installation was a snap, with no modifications needed and you can still use the stock floorboards!!! Took me about 5.5- 6 hours total, and that was with taking pictures, etc.
John
Make sure you inventory the kit to ensure all the parts are there. The kit contains all the needed pieces and are first quality billet and polished with a 2' belt. This allows you to use the stock floorboards.
John
Here we have the inner plate fitted (you may need to tap it in place with a rubber mallet), you need to remove the inner race from the tranny mainshaft. the front pulley has been assembled and slid on. There are various offsets available, but if you are replacing a stock primary the one that comes with the kit will do. There are bolts to secure it and they are all packaged and labeled making it an easy task. The instructions are very easy to read and fairly detailed. Red and blue Loc-tite should be used and torque specs in the instructions should be followed.
